Results 1 to 3 of 3
Thread: Throttle cable and front spring bushings
    Jan 2007
    Winona, MN.
    Default Throttle cable and front spring bushings
    I'm looking for a stock throttle cable assembly. Does anyone have one or know of a source? The same thing goes for a set of front spring bushings.-Thanks-Terry
    Memphis sold me a throttle cable a few years ago...they probably have more...check AB Linn first of course.
    VPW had the bushings for the front in 2005...came as a kit with the bolt and all...either them or Memphis on that...check AB there too.
    You looking to replace all 6 bushings in your front suspension (3 per side)? You know that there are 2 different sizes, right? I replaced my bushings and failed to realize this, I figured they would all be the same. I got the dimensions from Brute4c and just went to my local auto spring shop, they had them in stock. I'm not sure if NOS rubber stays good after 30-40 years. Good springs shops should also be able to make you new u-bolts while you wait.
  1. Throttle Cable for SBC
    By jlogan in forum Modified Tech
    Last Post: October 26th, 2008, 10:28 PM
  2. m-715 throttle cable
    By jaychevy420pitbill in forum Open Discussion
    Last Post: May 26th, 2008, 11:33 PM
  3. Throttle cable clip
    Last Post: March 2nd, 2008, 06:16 PM
  4. Throttle cable
    By porkchop in forum Open Discussion
    Last Post: February 6th, 2008, 07:56 AM
  5. Front spring eye bushings?
    By Brian Sisson in forum Stock Tech Archives
    Last Post: May 17th, 2004, 01:49 PM
