Thread: hetzer : Cab Mounting
    Default hetzer : Cab Mounting
    Cab Mounting
    Post by hetzer on Apr 17, 2006, 8:07pm
    Need to drill out and open up the cab mount holes on the frame pads, the backs are no problem as there is only one hole per pad. The fronts have two sets of holes in each pad.
    I presume that it is the inner set that are used for the bolts and mounting, but could somebody with their cab on verify that please?
    It's been awhile, the marks from the old mounts are covered over now, blah,blah,blah.
    Thanks!
    Default robertcowan :
    Re: Cab Mounting
    Post by robertcowan on Apr 17, 2006, 8:12pm
    i,ll check for you tomarrow.
    bob in tn.
    Re: Cab Mounting
    Post by brute4c on Apr 18, 2006, 9:17am
    Maybe this helps...I didnt read the question last night when I had my truck handy...
    If you mean the holes located at the arrows on the #5 line in this pic, then the center to center measurement is 42.5 inches:
    Default hetzer :
    Re: Cab Mounting
    Post by hetzer on Apr 18, 2006, 9:03pm
    Those would be the ones Jon, looks to me as they are pointing at the outer holes.
    Hmmm, my trans is now firmly in the way but I may be able to figure it.
    Re: Cab Mounting
    Post by brute4c on Apr 19, 2006, 8:18am
    I looked at my truck last night and it is indeed using the outer holes.
    Hopefully no major surgery is needed now that you are that far along...
  1. PTO mounting.
    By fisherman in forum Stock Tech
    Last Post: January 1st, 2015, 04:51 AM
  2. hetzer : Windshield Removal
    Last Post: November 12th, 2009, 04:21 AM
  3. hetzer : Seat covers
    Last Post: November 11th, 2009, 01:26 AM
  4. hetzer : Lost Master Cylinder Info
    Last Post: November 11th, 2009, 12:37 AM
  5. Div Np 205 mounting
    Last Post: April 27th, 2007, 11:56 AM
