Results 1 to 9 of 9
Thread: mikel : Shackle bushings?
    New Haven, CT
    Default mikel : Shackle bushings?
    Shackle bushings?
    Post by mikel on Nov 1, 2006, 6:39pm
    Hello,
    Do M715 shackles have bushings in the side that attaches to the frame?
    Thanks,
    Mikel
    Washington State
    Default fisherman :
    Re: Shackle bushings?
    Post by fisherman on Nov 1, 2006, 6:49pm
    Not sure what you mean by that Mikel. I just put new shackles on my frame. They came as a whole unit, with bushings and sleeve already installed in the shackle if that's what you mean.
    New Haven, CT
    Default mikel :
    Post by mikel on Nov 1, 2006, 6:59pm
    Hello,
    What I mean is that there is no metal to metal contact anywhere, that both ends of the shackle are rubber cushioned. Is this correct?
    Thanks,
    Mikel
    Washington State
    Default fisherman :
    Post by fisherman on Nov 1, 2006, 10:47pm
    Yes both ends of the shackles for the front springs, have the bolt tube surrounded by rubber. I had to use a two pound sledge and widen the shackle mounts on the front of the frame to get my new ones in. Yes there is metal to metal contact where the bolt tube through the shackle touches the frame mount where the bolt slides thru. Just a pivot point though. The front rear shackle mounts are fixed on the frame. Same setup on rear of rear leafs as on front of front leafs. Hope this helps.
    Default agengr :
    Post by agengr on Nov 2, 2006, 2:11pm
    fisherman, where did you get your new bushings from?
    Washington State
    Default fisherman :
    Post by fisherman on Nov 2, 2006, 9:30pm
    A few years ago Memphis had them on sale for nine or ten dollars apiece. I bought them then.
    SF Bay Area, CA
    Default hiker :
    Post by hiker on Nov 2, 2006, 9:51pm
    AB Linn had the shackles in the past also.
    Default bigbabyroger :
    Post by bigbabyroger on Nov 5, 2006, 12:18pm
    What about after market neopreme bushings! has any one gone that route? I would be intrested in that.
    Default robertcowan :
    Post by robertcowan on Nov 5, 2006, 6:10pm
    GET N.O.S ONES FROM AB.
  1. mikel : RV?ing in style
    By Mikel in forum PseudoZone - Open Archive
    Last Post: November 13th, 2009, 01:58 PM
  2. mikel : Tracked M715 pics
    Last Post: November 12th, 2009, 06:24 AM
  3. mikel : Front spring length?
    Last Post: November 12th, 2009, 04:33 AM
  4. mikel : More military FSJ's
    Last Post: November 12th, 2009, 04:04 AM
  5. mikel : The missing link
    Last Post: November 12th, 2009, 04:02 AM
