Results 1 to 7 of 7
Thread: Leaf spring bushings
    New Haven, CT
    Hi,
    Where can I find them (front and rear)?
    Thanks,
    Mikel
    Lone Pine, CA
    ABLinn had them when I needed them. Don't expect them to last a very long time though. I've never had good luck with rubber spring bushings (that I assume to be NOS). Urethane would be better but that'll take more sleuthing to come up with the right ones.
    Chris
    mikel, call springfield brake company 417-862-9233. they told me they could match any spring bushing. they also build custom springs. the front springs for my 78 1ton 4x4 chev. were 73.00 each i dont remember what the polyurethane bushings were. they also handle all models of vehicle brakes. hope this helps. larrywatkins
    New Haven, CT
    Thank you
    front spring bushings
    front eye-napa p/n 274-6523
    rear eye-napa p/n 274-1185
    just finished installing a set in my 68 m-715(s/n28493-8/68)
    Default Vin Registry and Member List additions
    Quote Originally Posted by harryestephens
    Does these part numbers apply to the rear springs also?
    Feb 2004
    N.W. Ohio
    The rear spring bushings are a steel on steel design. Theses are greasable. And if greased regularly, should never wear out. The biggest problem is lack of greasing & then you can't get them to take grease. You can heat them with a torch to get them to take grease.
    Happy Trails,
    Darryl
  1. airborne : Spring bushings
    By airborne in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 01:48 AM
  2. Replies: 5
    Last Post: August 1st, 2009, 10:50 AM
  3. Spring bushings?
    Last Post: February 12th, 2009, 11:43 AM
  4. Throttle cable and front spring bushings
    By terryb in forum Stock Tech
    Last Post: March 28th, 2007, 10:36 AM
  5. Front spring eye bushings?
    By Brian Sisson in forum Stock Tech Archives
    Last Post: May 17th, 2004, 01:49 PM
