  #21
Old November 22nd, 2018, 08:43 PM
Subybaja's Avatar
Subybaja Subybaja is offline
Private 1st Class
Subybaja is a Soldier
I think it looks fine. I might check the bolts after a bit of use.
Looking for more progress!
  #22
Old December 23rd, 2018, 06:24 PM
jhartings jhartings is online now
jhartings is a Soldier
Put the Dana 80 rear axle back on and rough aligned it. Also started cleaning up the Cummins engine, NV4500 trans and NP241HD transfer case. A ton of degreaser, towels and elbow grease.
  #23
Old December 23rd, 2018, 06:35 PM
Few more pics. Showing some individual components cleaning and painting. I will be painting the block soon and putting the drivetrain back in to see how this is gonna lay out with the cab and body.
  #24
Old January 15th, 2019, 01:18 PM
Painted the engine and accessories. Dropped the engine in the frame and started to get the cab set so I can do the cab and bed body mounts. Hopefully the engine mounts don't need to move but feel I might have to push back 4” or so.
  #25
Old January 21st, 2019, 05:35 PM
Took off the front clip from the old M715 frame and put it on the Dodge frame. Looks like I am going to have to move the engine back about 5-6" but this shouldn't be an issue. I plan on reusing the frame side of the engine mounts and just have my welder buddy make some custom engine side mounts. Next step........ move the cab over so I can start working on the front clip and cab mounts. Will probably have to trim about 1/2" of fender off the bottom so the Dodge spring towers fit. But will wait to do that when I put the mounts on.
  #26
Old January 26th, 2019, 05:26 PM
Cut off the sheet metal top and removed the seats from the cab. Next... door removal, removing the rest of the convertible frame, and then moving the cab over for fitting on the new frame/cab mount mock up.
1998 - 2019
Copyright 1998-2019
