Results 1 to 5 of 5
Thread: Grant steering adapter
    Jan 2008
    Montreal Canada
    Exclamation Grant steering adapter
    For the ones that have changed their steering using a GRANT adapter .... have you been able to still be using the horn ?? I may be missing parts in my bag but cannot seems to have the horn functional with the hardwares included.
    IF not i will be using a momentary switch in the place of one of the heater controls since i'm not having this option.
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
    Huntingtown,Md.
    Unhappy
    NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OO. Not only that, I couldn't get but about 3/4 of the nut back on the shaft, it just would not pull down anymore.
    Jan 2008
    Montreal Canada
    Quote Originally Posted by airborne View Post
    Also have the same problem ...... it's a secondary problem .... So i will have to mill something to have my aftermarket steering to the stock column ..
    Thanks ... it's confirming my questions ....... a push button for the inspection !!!
    M104A1 trailer
    I couldnt get the horn to work but the nut went down fine...at least I dont remember any problem with that...
    I didn't like the way the horn was setup anyway on the grant. I'm putting a pushbutton on the dash, too. No problems otherwise with install.
    DP
    Man invented the slowest form of transportation - the sailboat, Then decided to race them.
  1. safaritow : Steering wheel adapter
    Last Post: December 15th, 2009, 08:16 PM
  2. want to buy a sbc adapter to a t-98
    Last Post: February 16th, 2009, 04:24 PM
  3. grant steering wheel adapter
    By guswheels in forum Modified Tech
    Last Post: April 30th, 2008, 08:57 AM
  4. Steering wheel adapter
    By fng in forum Modified Tech
    Last Post: October 31st, 2007, 10:33 PM
  5. Grant Steering Wheel
    By BulletSponge in forum Modified Tech
    Last Post: August 28th, 2007, 06:50 PM
