Results 1 to 8 of 8
Thread: elohim1 : Mechanical Vs. Electrical Gauge
    Oxford, Ohio 45056
    Default elohim1 : Mechanical Vs. Electrical Gauge
    Post by elohim1 on Nov 5, 2006, 5:48pm
    I was looking into some autometer gauges for the M715 and see they offer electrical and mechanical. I see the electrical are twice as much $.
    Are they twice as good? Please give me the scoop.
    Chris
    Default robertcowan :
    Re: Mechanical Vs. Electrical Gauge
    Post by robertcowan on Nov 5, 2006, 6:08pm
    I LIKE MECHANICAL MYSELF. YOU CANT GO WRONG WITH AUTOMETER. ALSO STEWART WARNER MAKES SUPER NICE GAUGES STILL. AND WOULD LOOK MORE ORIGINAL IN THE TRUCK.
    BOB
    Mar 2004
    northern Arizona
    Default compexp :
    Post by compexp on Nov 5, 2006, 6:54pm
    I used all electrical except for the speedo - and now I wish I had done the speedo as well. The reason for that is that the electric speedo can be re-calibrated for different tires/gear ratios.
    Mechanical gauges require hard tube hookups to the back of the dash units. Everything today is electrical sending units to the dash. Easier to do.
    Post by robertcowan on Nov 5, 2006, 8:24pm
    MECHANICAL IS LESS TROUBLE PRONE, WATER PROOF-MUD PROOF SHOCK RESISTANT ETC. THE SPEEDO IS TOTALLY CALABRATABLE WITH THE LITTLE GEAR BOX FOR IT. JUST MY OPINION. WATER IN ELECTRICAL = NON-WORKING GAUGE I.E. CONVERTABLE M715
    Default tacomainoh :
    Post by tacomainoh on Nov 5, 2006, 8:32pm
    Break the tube to your oil pressure gauge and tell me which one you like better... hahahah
    Lone Pine, CA
    Default luckypabst :
    Post by luckypabst on Nov 5, 2006, 10:06pm
    Exactly, dude. It's nice not having pressure lines and capillary tubes into the driver's compartment. Mechanical gauges are technology from the good'ol days.
    Chris
    Post by robertcowan on Nov 5, 2006, 11:50pm
    RUN GOOD LINES THEY DONT BREAK. AT LEAST IN MY SEMI TRUCKS WITH (HOT ) -OIL PRESSURE, ( HOT ) FUEL PRESSURE ( 300+ PSI ) TURBO BOOST50-65 PSI , AIR PRESSURE125-130 PSI . IN OVER A MILLION MILES NEVER HAD A FAILURE....... I BUILD + FIX EQUIPMENT RIGHT !!!!!!
    Default barrman :
    Post by barrman on Nov 6, 2006, 9:29am
    Chris,
    I have a set of Auto Meter Sport Comp gauges in my M715. This is the 3rd vehicle these gauges have been in. 1937 Packard 120 hot rod, 1953 Studebaker hot rod truck and now this truck for the last 5 years. I bought them in 1992. Mechanical oil psi, engine temp, fuel psi and speddo. Electric tach, fuel level and volts.
    I love the simplicity and implied reliability of the mechanical gauges. But, as pointed out above. My speedo is off and I can't fix it without spending a good bit of money. Plus, when I was painting my cab a few months ago, I decided to leave the gauges in because I was still needing the truck as a daily driver and didn't want to chance the temp sender probe getting broken off while threading it through the firewall twice to remove and reinstall it. That meant the gauge panel had to stay in the dash as well. I just painted it all and I love the looks. But, it makes the gauge wiring a hassle since it can't be removed without draining the radiator.
    It all boils down to what you want to do. I have the same basic gauges in 3 current vehicles right now. I regret not going electric on all the gauges I put in my Mini a few years ago. Electric gauges take up less space and a Mini doesn't really have any space to spare.
    Here is a picture of my gauges in the M715 all painted up.
  1. 24v ro 12v gauge question
    By Duane in forum Stock Tech
    Last Post: September 10th, 2009, 05:44 PM
  2. Gas Gauge
    Last Post: October 14th, 2008, 01:59 PM
  3. Mechanical Vs. Electrical Gauge
    Last Post: December 24th, 2006, 04:40 PM
  4. mechanical brake caliper, cheap
    By Nuke_mcinfantry in forum Open Discussion Archives
    Last Post: May 17th, 2004, 12:36 AM
  5. volt gauge
    By koobster in forum Stock Tech Archives
    Last Post: February 22nd, 2004, 01:41 AM
