Results 1 to 6 of 6
Thread: Bed lifting tab hole size?
    Default Bed lifting tab hole size?
    My lifting tabs were cut off flush with the bed. I would like to fabricate new ones but could only guess at the hole size. If someone could measure the hole in theirs it would be greatly appreciated.
    The cesspool of WA state
    24 views and 5 hours later and no answer? I don't quite get that. Despite hoards of mosquito's and aggressive deer, I will do it. I went out and measured. My two front ones are cut off, my back ones are not. The hole is 1.5 inches exactly. The top of the hole is 3/4 from the top of the tab. The top of the tab is not a perfect radius. It is mildly bell shaped. If you are a detail nut like myself and want a picture to show the profile, let me know and I will take one.
    Hope this helps...
    Quote Originally Posted by Kaiserjeeps View Post
    Hope this helps...
    Some of us check in but once a day-- had I seen that post I would have provided the requested info.
    Thanks for being so detailed, and yes I am a bit of a detail nut but did find a picture. Appreciate you fighting the mosquitos and deer to get me this info.
    I get what you are saying nailhead. And thank you for guys like you. It just seemed to be a case of too many moving to fast for something so simple for so many views and crickets. It got handled.
    Jim67 the mosquitos are bad this year and the deer want an apple. I had to almost run. Glad you found what you were looking for.
    Jul 2009
    Louisville, KY
    Not sure you got an answer...Hope this helps.
    Thanks for all the help!
