Results 1 to 6 of 6
Thread: adk4x4 : Alternator issues
    Default adk4x4 : Alternator issues
    Alternator issues
    Post by adk4x4 on Sept 19, 2006, 7:36am
    I have a 67' M715 with alternator issues, big surprise right?
    It worked at one point, stopped working, then I took it to a guy who was by all accounts familiar with military alts, but it only worked again temporarily. I since moved away from that area and have no one local to call on. I have enough technical background to do most of the diagnostics and repair myself but lack the proper guidance. The TM's depict what I suspect as an older version of my voltage regulator and the checkpoints are not clear on mine.
    Anyone out there that could help me out, the alt seems to be in great shape but something is not right, what do I look for?
    Default kwai :
    Re: Alternator issues
    Post by kwai on Sept 19, 2006, 7:42am
    If it is putting the wrong voltage (too high or too low) you can adjust it. Not sure which alternator you have but usually there is a pipe-plug filled access hole near the rear of the alternator. Remove the plug and you will find a screw that is used to adjust the output voltage.
    Default adk4x4 :
    Post by adk4x4 on Sept 19, 2006, 8:11am
    No output voltage is being supplied as far as I can tell. The motor will not run if you disconnect the battery. On the voltage regulator, a broken solder connection was found but when fixed, this did nothing for the output. My regulator is a circuit board versus the antique looking thing in the TM. The alt is stock as far I can tell but maybe a bit newer generation than the TM depicts.
    Default k8icu :
    Post by k8icu on Sept 19, 2006, 8:52pm
    Is the little wire that hooks to the altinator there and in one piece. I had one that had a break in it and it wasn't getting the 24V from the Batter to excite it. These alternators are self exciting provided they have a voltage to use as the bench mark so to speak. Check it and make sure your getting 24V there.
    Default brute4c :
    Post by brute4c on Sept 20, 2006, 9:18am
    Good point Joe...reminds me that the excite wire, wire #468 at the alternator end, wire #27 at the on/off switch end, has been known to get chaffed through by the little metal cover piece that is on some versions of the alternators where the wires connect...shorts the wire right out...worth a check...
    Default adk4x4 :
    Post by adk4x4 on Sept 20, 2006, 12:28pm
    I found the rubbed wire when I rebuilt the truck, before the alt stopped the first time.
    Upon further investigation it was determined a rectifier diode was shorted and will require replacement...ugh...
    other items are suspect as well but the blown diode is a lock
  1. adk4x4 : Leaf spring lube
    Last Post: December 15th, 2009, 03:19 PM
  2. adk4x4 : 715 Alternator Rebuild Project Series
    Last Post: November 12th, 2009, 06:39 AM
  3. adk4x4 : NYS registration & inspection issues
    Last Post: November 12th, 2009, 03:56 AM
  4. Starting Issues.
    By gargemel_622 in forum Stock Tech
    Last Post: September 7th, 2009, 09:37 AM
  5. Traction issues
    By randyscycle in forum Open Discussion
    Last Post: April 24th, 2008, 03:11 PM
