Old May 14th, 2004, 07:37 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Default Reverse Lights
If you look really close at my avitar, you can see that I have both red tail lights on my roll bar and white lights. I plan on making the white lights a switched on and off bed light. I would also like to make them come on when I put my yet to be installed NV4500 in reverse.
Which would be better?
Ground the lights, power to light switch and power to reverse switch on trans, or make the switches the ground and the light have a permanant 12v + supply.
Thanks, I know that this is a simple thing, I am just looking for justification or a nessesity to do it differently than my first option above.
Old May 14th, 2004, 08:37 AM
65CJ5 65CJ5 is offline
65CJ5 is a Soldier
The common way to do it: Ground the lights, power to light switch and power to reverse switch on trans.
Stan
bdial bdial is offline
Basic Trainee
bdial is a Soldier
Wish I had an answer for you: but don't. Your question made me wonder about the T98A and a backup light switch. I've seen references to one in discussions re civilian version: any way to put one on ours?
Old May 14th, 2004, 05:21 PM
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
1st I get an X for you avatar so I can't look at your truck..2nd. If your truck is - ground keep it that way...switch the + lead and keep the ground constant.
Zone holster maker
Old May 14th, 2004, 09:29 PM
dave's Avatar
dave dave is offline
Private 1st Class
dave is an Observer
install a relay too to power the lights so you dont stress the reverse switch so much do it like you would when you hook up off road lights except run it thru the reverse switch to trigger the relay.
67 M725, 67 M715, 68 M715
  #6
Old May 15th, 2004, 02:09 PM
Barrman's Avatar
Chief 9-flats
I was planning on running the switches hot and the light permanently grounded. Thanks for reinforcing that thinking.
The relay thing has me thinking. You are suggesting that I run the toggle switch and the reverse switch into the same wire as the 12v + that closes the relay. The closed relay would then connect the lights to the 12v+ they need to come on. Right?
  #7
Old May 15th, 2004, 06:21 PM
WetCJ's Avatar
WetCJ WetCJ is offline
WetCJ is a Soldier
This is how I did a 62 Jeep pickup when the owner wanted the switch option.
Sorry, my picture didn't survive the size reduction well. On the left it says- Typical bosch style relay (I use Bosch 0 332 209 138)
The numbers on relay are- bottom 30, middle 87a, top 87, left side 86, right side 85.
  #8
Old May 16th, 2004, 06:20 AM
65CJ5 is a Soldier
Right, if you hook up the tranny rev switch and a toggle switch you can turn the reverse lights on whenever you need them without going in to reverse, yet they'll still come on whenever you go into reverse as well.
The relay is a real good idea if you are running more than a couple of regular small backup lights. Same for fog lights, electric fans, etc. Any high draw, high amp application should use a relay.
Stan
  #9
Old May 16th, 2004, 06:01 PM
Barrman's Avatar
Chief 9-flats
Thank you all for your help and ideas.
HTML code is On
24v led lights FullBird Modified Tech 14 February 8th, 2010 12:07 PM
brute4c : Reverse lights switch for T98 brute4c PseudoZone - Mod Tech Archive 1 December 15th, 2009 05:05 PM
Lights? johnny rezny Open Discussion 3 April 30th, 2008 09:05 AM
reverse light stranman Stock Tech 8 March 30th, 2007 05:39 PM
reverse lights IAN_M715 Open Discussion 16 January 24th, 2007 07:20 PM
1998 - 2019
Copyright 1998-2019
