Results 1 to 5 of 5
Thread: Broken Spring Hanger
    Default Broken Spring Hanger
    So I was on a search the other day with Search and Rescue looking for some guy who got stuck in the snow with this Mercedes (yeah, a Mercedes). We don't think he was in his right mind, because when he called dispatch saying he was stuck and walking down the road, he wanted to "Talk to the President, please patch me through to the President...". Not sure why he was like that, maybe off his meds or something, idk. Turns out he was actually just on the other side of our county, but we still had to search the roads in our county untill he was found because we had reason to beleive he was in our county.
    During the search I noticed my passenger side was sitting really low, like the bumpstop was almost touching the axle and I couldn't figure out why till I crawled underneath and discovered that the rear spring hanger broke off of the frame! Guess I was hitting some bumps and railing through the snow a little too hard. Appears to be just really shotty factory welds (40+ year old ones at that).
    What little weld was there barely penetrated into the frame. I cleaned the frame, repositioned the hanger, and welded every inch I could, top, side, bottom, inside, I don't think its going to come off again.
    Was a surprise, didn't think that would break. I welded on the other side too as well as the front hangers to strengthen them. Fun times.
    68 M-715
    67 M-725
    i was epically unimpressed with the welds on my truck when i cut the hangers off the frame. i am not surprised that it broke off
    67 #18820 mostly stock...
    Barrman has had 2 break off if I remember that right...he welded them up and is good to go since...others have had this problem as well.
    Jun 2007
    Alexandria KY
    The welds on the right side of my '67 are really crappy. The welds on the left side are much better......
    Maybe I should grind 'em down and go over them.
    '67 M715 '42 GPW '45 MB
    Richboro,Pennsylvania
    The whole front end of these truck is sort of messed up from the factory. The front leaf springs are not parallel...it think mine are 1" narrower at the rear hangers than they are at the front shackles. Probably adds a fair amount of stress to the welds. I know mine isn't the only one, as I have measured some at wrecking yards also....Might have to get the welder out and repair mine now.
  1. warthog : Spring Hanger & galvanize
    Last Post: November 10th, 2009, 11:30 PM
  2. broken front leaf spring
    By jpsnblood in forum Stock Tech
    Last Post: July 1st, 2009, 11:45 PM
  3. spring hanger
    By wrecker in forum Stock Tech
    Last Post: April 15th, 2009, 12:02 PM
  4. Broken frame spring mount pins
    By ColHart in forum Open Discussion
    Last Post: April 5th, 2007, 10:03 PM
  5. spare tire hanger
    By rjenkins in forum Modified Tech
    Last Post: January 7th, 2007, 09:23 PM
