Results 1 to 7 of 7
Thread: Accelerator pedal ?
    Apr 2009
    Southeast Missouri
    Default Accelerator pedal ?
    I’ve been messing with the “New” truck and the accelerator pedal felt funny, so after looking it over, the only thing going from the pedal assembly to the bracket under the dash is a spring, is this correct. It’s really hard to give the truck gas smoothly because of the spring pressure.
    page 76 of parts manual TM 9-2320-244-34P
    you can down load the manuals here on the zone http://www.m715zone.com/vb/view.php?pg=manuals
    "An axe. A real axe. An 'I'm out of ammo, let me grab the axe', type of axe!" steelsoldier FrankUSMC
    Apr 2009
    Southeast Missouri
    OK thanks a lot, looks like I'll be making one , don't figure the local auto parts store will have one.
    Check with your local hardware store, as they generally carry a multitude of similar springs in a variety of sizes. I found a useful brake clutch pedal return spring at True Value.
    Memphis Equipment has most or all of the metal parts for this...
    what are you missing... i have most of the metal parts from a parts truck
    Apr 2009
    Southeast Missouri
    The only thing I think is missing is the linkage rod #10.
  1. sermis : Accelerator peddle & cable
    By sermis in forum PseudoZone - Open Archive
    Last Post: November 10th, 2009, 11:25 PM
  2. Accelerator cable: too much slack
    By MarknessMonster in forum Stock Tech
    Last Post: April 27th, 2008, 08:29 PM
  3. Gas Pedal
    By rboltz in forum Stock Tech
    Last Post: December 26th, 2007, 02:23 AM
  4. Gas Pedal
    By Gill in forum Stock Tech
    Last Post: July 25th, 2007, 02:12 PM
  5. gas pedal
    By reltrk in forum Modified Tech
    Last Post: February 13th, 2007, 08:59 AM
