Thread: mikec3820 : need to know wheel bearings
    Default mikec3820 : need to know wheel bearings
    Post by mikec3820 on Apr 10, 2006, 5:12pm
    Do any of you fine folk know what size the nuts holding the wheel hub on the spindle (front passenger) are so I can get a socket to fit them. Also, My bearings are fried and I am not sure of a part #. Anybody know if the local parts house would have them.
    Lone Pine, CA
    Default luckypabst :
    Re: need to know wheel bearings
    Post by luckypabst on Apr 10, 2006, 7:14pm
    I thought I had the bearing and race numbers in my notes but I guess not. They are common parts, just take in the number off the bearing and the number from the race.
    Front wheel grease seals are Nat'l #475384, about $20 each.
    I wanna say the nut is 2-9/16". Best to measure yours if nobody chimes in.
    Default mikec3820 :
    Post by mikec3820 on Apr 11, 2006, 5:37am
    Thank you. I'll try to get a part number off the bearings, but one of them completely desentigrated going down the road.
    Post by brute4c on Apr 11, 2006, 9:06am
    I think these are correct...
    Outer-Timken #18790 Rated @2950 lbs.
    Cup #18720
    Inner-Timken #387A Rated @4900 lbs.
    Cup #382A
    Default mikec3820 :
    Post by mikec3820 on Apr 11, 2006, 7:52pm
    Thank you. I'll call right now and see if they are in stock here. I suppose i will disect the front spindle and hub this weekend.
    Post by brute4c on Apr 11, 2006, 9:50pm
    I have a hub socket...its iss 2 9/16ths inch...
  1. 230 rod bearings
    By SR. in forum Modified Tech
    Last Post: March 12th, 2010, 03:32 AM
  2. uscgmatt : Rear axle wheel bearings.
    Last Post: November 11th, 2009, 12:02 AM
  3. Connecting Rod Bearings
    By rboltz in forum Stock Tech
    Last Post: February 12th, 2009, 02:29 AM
  4. NAPA part numbers for front and rear wheel bearings?
    Last Post: January 5th, 2008, 11:33 AM
  5. rear wheel bearings
    By terryb in forum Stock Tech
    Last Post: March 6th, 2007, 07:20 AM
