Considering Rockwell swap. But have some questions for the guys that have done it before.
This is my question I've run 44 mudders in the past with stock dana 70 & 60. With a lift of just a inch more that a axle and shackle flip. I would only have a slight rub (front) if I really put it into a bind.
Stock rear axle has WMS measurement of 72.5 inches, Front has a WMS measurment 73.5 inches.
With all that said if I swap to Rockwells with DimensionsWheel mounting flange-to-flange
Front axle - 79 1⁄2 inches Hub flipped out. 69 1/4 hub flipped in
Rear axle, single wheel configuration - 69 1⁄4 inches
Rear axle, dual wheel configuration - 79 1⁄2 inches
The trucks i've seen with hubs fliped in for a 69 1/4 WMS looks like a much cleaner setup than the wheels fliped out at 79 1/2 WMS. But this configuration makes me wonder about two things 1 =rub problems with 44's since pulling the tire tigher under the finder. 2= with hubs flipped in are you stuck with pinion brakes or is there a solution for running disk brakes with hubs flipped in? at 69 1/4 WMS.??
I guess the best way to put it. I'm looking to get advise on Pros and Cons of hubs flipped in 69 1/4 WMS v 79 1/2 hubs flipped out.
All of these trucks are killer. Not looking to offend anyone about there choice of how they setup their Rockwell 715. Just looking for feedback from the ones that have done it and what they found to be best.
Thanks in advance for your advice
CrashMorriss
