Page 7 of 15 FirstFirst 123456789101112131415 LastLast
Results 61 to 70 of 150
Thread: yes its a total rebuild
  1. #61
    cab going back together
    m715 180 by tom boyer, on Flickr
    m715 181 by tom boyer, on Flickr
  2. #62
    cab primed
    m715 182 by tom boyer, on Flickr
    m715 183 by tom boyer, on Flickr
  3. #63
    Looking great!
    Interesting (to me) that you are keeping the hard top. Our's has one and it's the one thing we know will change no matter what the build direction ends up. My wife is pushing for a restoration, I am pushing for a crawler... (She normally wins).
  4. #64
    I have had CJ 5 with a soft top it was not a good way to go here in alaska.
  5. #65
    Quote Originally Posted by tomb View Post
    Oh right!... Alaska... :facepalm: that makes total sense!
  6. #66
    working on the transmission the pto was not shafting right opened it up to find some one drilled and taped a new hole to fix a broken bolt.
    m715 184 by tom boyer, on Flickr
    m715 185 by tom boyer, on Flickr
    m715 186 by tom boyer, on Flickr
    after burning the bolt with my EDM I broke a tap off in the hole
    m715 187 by tom boyer, on Flickr
    had to burn the tap out then clean the hole
    m715 188 by tom boyer, on Flickr
  7. #67
    moving on to get things up to were I am at,wiring time. fuse box and inside cab
    m715 193 by tom boyer, on Flickr
    m715 197 by tom boyer, on Flickr
    m715 199 by tom boyer, on Flickr
    m715 198 by tom boyer, on Flickr
    had to pull the wires out of the connector to shorten the wires
    m715 196 by tom boyer, on Flickr
  8. #68
    had to build the door lock parts for the drivers side. used a summit decal for the temple and cut around it.
    m715 201 by tom boyer, on Flickr
    m715 202 by tom boyer, on Flickr
  9. #69
    Feb 2007
    Bloomfield CT
    Sweet work, keep it up!
    Is that real money?
  10. #70
    wiper motor spacer that locks the motor to window frame.
    m715 203 by tom boyer, on Flickr
    m715 205 by tom boyer, on Flickr
    m715 204 by tom boyer, on Flickr
