Thread: Looking for replacement cab corners
    Default Looking for replacement cab corners
    My can corners are shot! Been looking on the web and coming up short please help.
    New Haven, CT
    If you are replacing the rockers, it's very easy to leave them a bit longer and fabricate the cab corners out of them.
    Quote Originally Posted by Mikel View Post
    What we did!!
    Jun 2015
    Palm Harbor, Florida
    Hi, I am not replacing rockers. They look good. Does anyone know where I can get cab corners. Thanks.
    Mar 2018
    North central Indiana 46979
    Do you have some info about doing that for a newbie.. Mine are shot as well.
    New Haven, CT
    Quote Originally Posted by Tsbritt3150 View Post
    Basically what you do is leave the rockers about 1.5-2" longer than needed, then gently roll the excess inwards and weld them together, using a flat piece of sheetmetal to recreate the rest. After you grind the welds, it will look like a factory cab corner, minus the weld seam.
