Results 1 to 10 of 20
Thread: NAPA Valve Cover Gasket
    Default NAPA Valve Cover Gasket
    The 230 valve cover cover gasket is no longer stocked at NAPA. They can order one with the new number VS50258C. $10.59 plus special order shipping. The thicker one is no longer available at all. They are not sure how long the standard one will be available.
    Thanks for the info...do we know how much thinner this one is or any other differences?
    Default Sizes
    Standard is 5/32" and is available. Thick is 7/32" and is no longer available. When I get it, I'll post any relevant info about it.
    Default Here it is
    Does this look right? It seems to be correct looking at the valve cover on the engine but without removing the cover, I can't tell. It is cork
    SF Bay Area, CA
    Unfortunately, that's not the correct gasket. The 230 OHC gasket is a moulded rubber arrangement that fits over the lip of the valve cover. There are no holes in the gasket.
    Default Good Old NAPA
    Automotive stuff is not my vocation but I will say this. In my dealings with NAPA both locally and online have not been good. They must have the most antiquated IT system out there. You can look up the same engine and get different results. I just looked again and that gasket is shown as the one for the 230 CID early-mid 60's engine. I had the same problem with thermostat gaskets and fuel pump gaskets.
    They do have some 232 stuff listed under the 230...has happened before with other stuff...
    Another point on the gasket...one long side is dead straight...
    SF Bay Area, CA
    Here's one on ebay but it looks somewhat dried out from the picture.
    http://cgi.ebay.com/ebaymotors/NOS-W...Q5fAccessories
    SF Bay Area, CA
    How about Memphis Equipment or AB Linn for the gasket.
    You are correct. Ding a reverse lookup with Fel-Pro shows this gasket for the 232. Not the 230 the NAPA site shows. (no refunds on special orders even if their site is wrong)
  1. Valve cover gasket
    By crisp in forum Stock Tech
    Last Post: February 7th, 2010, 10:56 PM
  2. foreverunstopable : Valve cover bolt torque
    Last Post: December 15th, 2009, 03:04 PM
  3. Valve cover gasket.
    By Beltfed Only in forum Stock Tech
    Last Post: February 19th, 2009, 01:41 PM
  4. My Valve Cover and too much time...
    By TheWarTapes in forum Stock Tech
    Last Post: October 21st, 2007, 08:24 AM
  5. Original color of the Tornado valve cover?
    By maddawg308 in forum Stock Tech
    Last Post: July 16th, 2007, 11:10 PM
