Results 1 to 6 of 6
Thread: Ford 300
    Default Ford 300
    Has anyone ever put a Ford 300 Inline six in their M715?
    If you have, would you recommend it? Any particularly good or bad parts of the engine or the installation process?
    I would have to agree, the sbc is cheap and easy and parts are off the shelf anywhere. The effort to adapt the Ford 6 may cost more than the entire chevy swap.
    Aug 2007
    central central wisconsin
    All you need to do is buy a T-18 Ford trans. Their cheap, I paid 125.00 for mine and just put new oil in it. It will bolt right up and unless you have a winch, it works great. I have a 351 Cleveland with the T-18 in mine. The T-18 (which is called the rock crusher) is basically the same as the T98 except the T-18 has better insides, and has the PTO on the passenger side. The Ford T-18 is one of the top 3 non-overdrive transmissions made. Be different, everyone and their sister puts in a 350 chevy.
    Luckypabst put a fuel injected 300 in his truck. He then proceded to drive it all over Southern California. Including some places that the access road looks scary. He reported it was great. Chris should see this sometime in the future and chime in.
    I realize this is a little old judging from the date. You likely already put in a sbc. There is a guy in VA that substituted a Ford 300 in line six. Had to make an adapter plate but was nothing too difficult. He was in a back issue of either Peterson's or Four Wheeler. His name is Bill Gallihugh and he lives around Mt. Pelier, VA. If you need his number drop me a note. I can find it. The 300 six for all you non-Ford fans had a pretty good history of being a reliable torquie motor.
    The adapter plate is not rocket science but does require an above average skill to measure right and make maily to get the depth s right.
    Quote Originally Posted by nolfy View Post
    A smallblock install in two days! Man that is fast.
  1. What does it take to ford?
    By buzzbike71 in forum Stock Tech
    Last Post: May 22nd, 2011, 12:35 PM
  2. ford 300
    By RJBM715 in forum Modified Tech
    Last Post: November 23rd, 2009, 05:42 PM
  3. ford 300 help
    By FullBird in forum Modified Tech
    Last Post: July 18th, 2009, 04:59 PM
  4. what does it take to put a ford 390 in a 715
    By 05strokinfx4 in forum Modified Tech Archives
    Last Post: May 9th, 2004, 09:10 PM
