Results 1 to 4 of 4
Thread: binfordm715 : Blackout Driving Light base mount
    Port Orchard, Wash.
    Default binfordm715 : Blackout Driving Light base mount
    Post by binfordm715 on Jul 30, 2006, 11:58pm
    I can't find the coffee-stained drawing Oilcan gave me at the FE. Grrrr....
    I wanted to get the specs to Saxon, who just happens to be a sheet metal man! And see if I can persuade him to pound one out for me.
    Anyone have a sketch with dimensions? I can bend the two mounting tabs myself , so all I'd need are the dimensions of those, not the angle. All the other angles are 90 degrees, so that's not a problem.
    Thanks!
    Default brute4c :
    Re: Blackout Driving Light base mount
    Post by brute4c on Aug 2, 2006, 10:07am
    Heres the best specs I can give....
    The plate is 4 inches wide from end to end and is 1/16th inch thick.
    I made a side view drawing of the plate by tracing the spare plate I have:
    Dimensions:
    A= 3/4 inch
    B= 5/8ths inch
    C= 4 inches
    D= 1 13/16ths inch
    E= 7/8ths inch
    Top view, simple, just trying to show the bolt spacing and hole sizes...
    The holes on the edges, on the flanges in the first drawing, are 9/32nds inch diameter.
    The hole centers on the short edge of the first image, section A, are 3/8ths inch in from the long side edge. Each of the 2 holes in that end are 1/2 inch on center in from the short side edge, there are 3 inches center to center of the 2 holes.
    The hole centers on the long edge of the first image, section E, are 7/16ths inch from the long side edge. As with the other end, each of the 2 holes in that end are 1/2 inch on center in from the short side edge, there are 3 inches center to center of the 2 holes.
    The large flat top area has 3 holes as seen in the 2nd image, section C. The holes are all 1/2 inch on center from the side edges of the plate. The 2 holes on the upper part of the 2nd drawing...the one on the left, toward the short flange side, is 9/16ths inch on center from the edge...the one on the right is 11/16ths inch on center from the opposite edge. The 2 are 2 3/4 inches on center from each other. The single hole on the other side is 2 inches on center from each edge...dead center of that 4 inch section.
    If anyone needs more info, just ask.
    EDIT: Ihad dimensions forA, B, D, and E swapped around before...corrected now...
    Default brute4c :
    Post by brute4c on Aug 2, 2006, 10:09am
    Also, note that the left flange in the first pic is straighter than I thought it was...though there is some bend to it...and the drawing is not perfectly level...section C should be horizontal.
    Default elwenil :
    Post by elwenil on Aug 2, 2006, 11:09am
    Awesome Jon! Just what I needed, thanks!
  1. Another 12v blackout hood light conversion
    By randyscycle in forum Modified Tech
    Last Post: March 3rd, 2021, 06:41 AM
  2. Blackout light hood bracket tech
    By migz in forum Stock Tech
    Last Post: October 24th, 2011, 01:44 PM
  3. Blackout stop light.
    By KsM715 in forum Stock Tech
    Last Post: March 30th, 2009, 09:53 AM
  4. Blackout Light Bracket drawing help
    By ColHart in forum Stock Tech
    Last Post: April 29th, 2008, 09:31 PM
  5. Where to mount my Blackout light
    By fisherman in forum Stock Tech
    Last Post: April 4th, 2008, 08:33 PM
