Results 1 to 6 of 6
Thread: Valve cover gasket
    Sep 2009
    Jax, FL/ Fayetteville, NC
    Default Valve cover gasket
    Anybody know where I can find a valve cover gasket? Also, (total noob question), my flywheel panhousing has no drain plug. im not sure if is even supposed to be one there but it is threaded so i assumed. and ideas on either would be great.
    Jul 2009
    Louisville, KY
    Memphis Equip has the gasket, I believe around 12.95. Tell them you don't need it tomorrow (unless you do) or they will hit you with 2nd day delivery, expensive shipping...another $12. That's what they did to me.
    I believe the plug is suggested if you drive through deep water or mud.
    The plug is for the fording kit - you can use a regular pipe plug I think. I've never put one in mine but there have been several discussions over the years on this board. Might want to search plug with fording or pressure.
    भगवान तुम्हें प्यार करता है
    The plug is only in when fording, the rest of the time, mine sits in the glove box with a light coat of grease on the threads inside a ziplock bag...
    If you want to pay $1 plus shipping, I'll send you one...pm me.
    Sep 2009
    while ive got you on the subject, ive searched and searched on the internet (my resources are limited, military internet doesnt let me look at some websites) for a fording kit. should i just build my own?
    VPW had some but I dont know if they still do...
    Have you tried Memphis and VPW to see if they have any of the parts?
    I have ne of the valve you would need...but you would need a lot more...
  1. foreverunstopable : Valve cover bolt torque
    Last Post: December 15th, 2009, 03:04 PM
  2. NAPA Valve Cover Gasket
    By rboltz in forum Stock Tech
    Last Post: April 2nd, 2009, 11:03 AM
  3. Valve cover gasket.
    By Beltfed Only in forum Stock Tech
    Last Post: February 19th, 2009, 01:41 PM
  4. My Valve Cover and too much time...
    By TheWarTapes in forum Stock Tech
    Last Post: October 21st, 2007, 08:24 AM
  5. Original color of the Tornado valve cover?
    By maddawg308 in forum Stock Tech
    Last Post: July 16th, 2007, 11:10 PM
