Results 1 to 10 of 18
Thread: My build continues
    Jan 2007
    Montana, East of Billings
    Default My build continues
    The build of my '68 715 that was going to take a week looks like it will take all summer. It has rained for the last week & a half which makes it hard to work out side. But progress is being made. The '78 Ford NP205 is now in place resting on mostly the stock mounts combined with some brackets that came with the t-case.
    The front and rear drive lines are connected up using combination size u-joints that fit the Ford yokes and the stock shafts.
    I may use the center from a CV joint to make the shaft between the trans and t-case.
    The next step will be to cut out and move the engine brackets to line up with the engine mounts. The engine is setting on the exhaust manifolds now.
    Mar 2004
    northern Arizona
    I'm in the same ark, brother - been raining almost every day here.
    Have a J-truck ripped apart waiting on nice weather and a not-so-lazy owner to get going on it.
    67 M725 67 M715 68 M715
    Springdale, Arkansas
    Lookin' goood Heepey! Nice work, I discovered it takes a little bit more effort than planned, huh? Looking really nice tho' and keep sending the pics...thanks. BTW what size engine is that?
    Jan 2007
    Here's the doner vehicle:
    '92 Suburban 2WD; 350 TBI;4L80E; hydroboost brakes; tilt steering column with all switches and shifter for the AT.
    Jan 2007
    I got a little more done tonite. Notched the cross member and put in the saddle or the tranny mount.
    Jan 2007
    Got the jack shaft in today. Used the center part of a CV joint as a shaft.
    Here is the new CV shaft with the original shaft next to it.
    The slip yoke in the trans is the stock Chevy part seperated from the drive shaft.
    The shaft I used is the center section from a double cardin CV joint. The part I used is Precision #647 from O'Reilly's. These can also be gotten from old Caddy drive shafts, but its worth the 45$ to just put the new parts together.
    The ujoints are Precision #445, a combination size joint to adapt the trans yoke to the smaller CV center. The second joint is #319 to adapt the CV to the Ford NP 205 t-case. This same joint worked to adapt the stock drive shafts to the t-case.
    With the back nearly done I can start working on the front engine mounts.
    Mar 2004
    northern Arizona
    cool, keep the info coming!
    Man, you work fast! Looks good. You must have done this before.
    Jan 2007
    China Lake Naval Base, SoCal
    way too fast... Great work and fun to see things happening!!!
    mine just sits... and sits... yesterday the boys moved the parts in the shop from one area to another cause they were getting in the way.
    Go Ahead, Make my day
    Looks great, thanks for the info!
    How did you figure out how/where to mount your transfer case and trans/engine combination to keep everything in line?
  1. My Build
    By spgirard30 in forum Modified Tech
    Last Post: February 2nd, 2016, 08:45 AM
  2. my build
    By chadriley5 in forum Modified Tech
    Last Post: January 23rd, 2010, 09:05 PM
  3. #37 build
    By FlatlinesUp in forum Modified Tech
    Last Post: December 13th, 2009, 10:02 PM
  4. binfordm715 : The Transformation continues....
    Last Post: November 11th, 2009, 01:35 AM
  5. Another 4bt build
    By Burritoboi5 in forum Modified Tech
    Last Post: October 6th, 2009, 06:46 PM
