Results 1 to 7 of 7
Thread: airborne : Spring bushings
    Huntingtown,Md.
    Default airborne : Spring bushings
    Spring bushings
    Post by airborne on May 26, 2006, 7:09am
    Guys, can you change the bushings WITHOUT taking the springs off? I see no way on the back at all. Thanks,Dave.
    Default brute4c :
    Re: Spring bushings
    Post by brute4c on May 26, 2006, 9:20am
    Dont they need to be pressed out? I can see that being a big pain when they are on the truck...
    Default socal715 :
    Re: Spring bushings
    Post by socal715 on May 26, 2006, 10:04am
    Pretty sure they need to be pressed out..... if you have a portable hyd. ram maybe you could do it... but then you'd have to brace it against something... and most likely bend a part of the truck that way.. another option would be to torch them out.... but then again you'll need to press the new ones in... so that doesnt help much.
    Default brute4c :
    Re: Spring bushings
    Post by brute4c on May 26, 2006, 10:37am
    Thats what I am thinking....
    Atlanta, Ga.
    Default bluesman2a :
    Re: Spring bushings
    Post by bluesman2a on May 26, 2006, 2:02pm
    you can do it... It's a PITA either way though. Couple of suggestions:
    1) Use a ball-joint/u-joint press to press them out.
    2) Mine were more stubborn than that. I had to torch/plasma out the center/rubber pieces then once those are out you can take a sawzall and cut a score into the outer metal part of the sleeve. Once you have that all the way through you can take a chisel to the rest and punch it out.
    3) You may also have some luck with an air chisle, I used it for some of mine and it was OK, but not great.
    Lone Pine, CA
    Default luckypabst :
    Re: Spring bushings
    Post by luckypabst on May 26, 2006, 2:05pm
    Not worth it in my opinion. I took my springs to work and with just a few minutes per bushing on the hydraulic press, I was done. You'll be fighing those things for half a day or more if you try to do it with the springs installed.
    Not a bad idea to swab the new ones with anti-seize before you install them. And NOS bushings will only give you a few years service according to my experience with various projects.
    Chris
    Huntingtown,Md.
    Default airborne :
    Re: Spring bushings
    Post by airborne on May 27, 2006, 10:06am
    Thanks to all. I guessing off they come at some point in time. Maybe when and if I do a S O A. I might do 10 miles a year in the truck,so it's not a big deal just wondering about it.
  1. Replies: 5
    Last Post: August 1st, 2009, 10:50 AM
  2. Spring bushings?
    Last Post: February 12th, 2009, 11:43 AM
  3. Throttle cable and front spring bushings
    By terryb in forum Stock Tech
    Last Post: March 28th, 2007, 10:36 AM
  4. Front spring eye bushings?
    By Brian Sisson in forum Stock Tech Archives
    Last Post: May 17th, 2004, 01:49 PM
  5. Leaf spring bushings
    By Mikel in forum Stock Tech Archives
    Last Post: April 2nd, 2004, 07:51 PM
