Results 1 to 4 of 4
Thread: stanman : tires again
    Default stanman : tires again
    tires again
    Post by stanman on Sept 28, 2006, 11:35pm
    Would the Mickey Thompson Baja Claw Radial 315/75R16 (35x12.50 I assume) fit on the stock wheels? In my Jegs book it says it fits an 8-10 inch rim?
    thanks for your help
    Default brute4c :
    Re: tires again
    Post by brute4c on Sept 29, 2006, 9:01am
    Yep...people run up to a 13 inch wide 38 inch tall tire on a stock rim.
    Northern Colorado
    Default fsjguy :
    Re: tires again
    Post by fsjguy on Sept 29, 2006, 12:14pm
    They should fit fine. I had regular AT tires with those same dimensions on my stock wheels.
    Default treepusher :
    Re: tires again
    Post by treepusher on Sept 29, 2006, 9:42pm
    I think the stock rim is about 6.5 inches wide. You can mount a 34x9 on a bicycle rim but that doesn't mean is OK.
  1. stanman : np201
    Last Post: November 12th, 2009, 05:23 AM
  2. stanman : Vigilante 327 V8
    Last Post: November 12th, 2009, 05:21 AM
  3. stanman : tires
    Last Post: November 12th, 2009, 03:15 AM
  4. stanman : overdrive
    Last Post: November 12th, 2009, 01:36 AM
  5. stanman : oil pressure
    Last Post: November 12th, 2009, 12:24 AM
