Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Hood number
  1. #11
    Feb 2004
    Silver Lake Sand Dunes MI
    Quote Originally Posted by Berks58 View Post
    I'm thinking that it might be 03G21868. Looking at the sticky it shows only three digits then a letter. Unlike earlier vehicles that had 4 then the letter. Just trying to get a definitive answer before I stencil the wrong number in her
    Looking at your pics I would say that it was most likely 03G. The only other possibility would be 03C, everything else will have a different shape and they did not seam to get very high in the alphabet before production stopped. The month that it was built will give you the most definite answer as to which one it is. A truck built in Feb-March will most likely be a 03C and a truck built later in the year, say around Sept. on would be 03G. Good luck, and if you need any help with markings, let me know. http://www.deltateamdecals.com
    Dave
  2. #12
    May 2018
    Berks County,Pennsylvania
    I'm going to have to get stencils from you but the paint is still too fresh. Weather is not cooperating!
    Anyways, here is some of tonight work. It's a 4.0 with an ax-15, nwf doubler, and a Dana 300 with 4:1 gears. Was going stock until the motor developed a nasty rod knock. Had to change direction and I had the drive train laying here so In it went. As you can see I have a ton to finish by Friday AM. It will be done enough for the event is going to.
  3. #13
    Feb 2004
    If you go with a decal set, it can be added right away and you don't have to wait for the paint to fully cure before applying them. I've put decals on the next day after paint before without and problems. Plus decals are actually the proper marking for our era of vehicles. The Army started using them in 1962 and used decals up until the subdued camo patterns of the mid 70's.
    Dave
