Page 8 of 12 FirstFirst 123456789101112 LastLast
Results 71 to 80 of 114
Thread: Restoration of 03N21368
  1. #71
    Jun 2014
    Eastern Maine
    Great news Don.
  2. #72
    Jun 2014
    Eastern Maine
    Test drove the truck last night, she primed from a dry fuel system in about 15 seconds, the rebuilt pump works great. She started right up and drives great, at least down my short road, all the lights and gauges work, 4x4, cooling temp steady @ 160. Problem is I have a couple of class 3 oil leaks coming from the head/block seam and where the head meets the timing cover on the fuel pump side, looks like my best bet is to just replace the head gasket now rather than patch with rtv.
  3. #73
    Jan 2011
    Fernandina Beach, FL
    Thanks again, I just got off of the phone with them. They have them listed under the FSN and have over 500 of them! They are ~ $5 each, so I ordered four just incase I mess one up.
    Thanks again for that picture and yes, they have tons of stuff and are only a phone call away!
    Ordered the Battery frames on Monday, they were delivered on Wednesday!
  4. #74
    Jan 2011
    They are in excellent, 1973 condition. But they dipped them in paint and there are several areas with no paint. I have them drying outside after a respray with Rustoleum 7777 Satin Black. I just checked, I had bought 3/8" rod for the "J" bolts. I will have to go get some 5/16" rod. Easy to bend; easy to thread.
    Thanks again!
  5. #75
    Jan 2011
    And on close examination, they have a left and right side! L, R stamped on the ends. Hanging from my technical paint fixture (saw horse ) in the sun drying.
    I will go out and get some 5/16 rod from Home Depot today and bend and thread later this week. I may have to paint them also on my technical paint fixture!
  6. #76
    Jun 2014
    Eastern Maine
    They do have an excellent shipping department, I never noticed a L/R I will have to look.
  7. #77
    Jan 2011
    Quote Originally Posted by m38inmaine View Post
    Not much different... side to side.
  8. #78
    Jun 2014
    Eastern Maine
    While waiting for my head gasket to show up I am doing a few detailing chores. The retaining chain and clip for two of my shackles were missing so I rounded up the necessary hardware to replace them. The chain is #25 x 6" sash chain and to attach it to the shackle a #2 x 3/16 drive screw. I have plenty of extra of this material if someone should need it.
  9. #79
    Jun 2014
    Eastern Maine
    More goodies from Memphis not listed on the site, transfer/brake shift boot/seal and steering shaft coupling seal.
  10. #80
    Jun 2014
    Eastern Maine
    Well with what appears to be a successful head gasket repair I am back on track. Took it out tonight for about a half hour on my road, good oil pressure and temperature, no leaks. I can hear what sounds like a "dry" bearing in the transmission, hopefully with some road speed the oil will splash around an cure it. Only casualty was half way through the test drive my RH low beam went out, installed a spare and back in business. Next on to painting the hood and doors.
