Results 11 to 20 of 21
Thread: Transmission leak.
  1. #11
    SF Bay Area, CA
    Memphis Equipment has one on Ebay currently, auction # 220274979248
    http://cgi.ebay.com/ebaymotors/M715-...spagenameZWDVW
    Also AB Linn has had them in the past, usually the cheapest.
  2. #12
    Thanks Hiker, I'll call Memphis tomorrow.
  3. #13
    Got my truck back together this afternoon, what a chore! Ran out of time, just need to refill it with gear oil and test drive. At least everything is clean under there now.
    Thanks for everyones help and suggestions. Thought I would post a picture.
    [img=http://img241.imageshack.us/img241/3931/m715eeh9.th.jpg]
  4. #14
    SF Bay Area, CA
    Nice looking truck!!
  5. #15
    Jester Guest
    I get to do this project this weekend to seal up the bolts. Thought it was the rear seal but discovered that its not leaking - must be the bolts.
    If you unbolt the crossmember and the trans mount, will the crossmember just slide back? Enough to get to the bolts?
    Txs
  6. #16
    8 bolts hold the transmission crossmember on. Undo them and attack the crossmember with a BFH once you support the transmission. Just watch the clearance for the front drive shaft if you go too far.
    However, I think you are making this harder than it should be. A combination wrench should let you get to each and every bolt with some creative arm positioning. I just looked at 2 of the T98's sitting in my class and I am pretty sure you don't need to move stuff out of the way to get to the rear seal housing.
  7. #17
    Jester Guest
    Correct, you can get to the seal housing but not the mounting bolts (#7 in the diagram). Those are what I think is leaking.
  8. #18
    And those bolts love to leak...
    Check the threads to see if they have been flattened or widened over the years...replace if they dont look up to snuff.
    Use some threadlocker on them and snug them up good...they love to work loose.
  9. #19
    Jester Guest
    Pulled the crossmember and trans mount. The bolts were tight but looked like the lower was leaking. Reassembled with a little sealant.
    Kinda of a pain but worth it.
  10. #20
    Sep 2016
    SW New Hampshire
    Default Drilling holes in the cross-member
    The Quirks manual says to periodically tighten the rear transmission bolts, however, it's not that simple, and I found that the rear passenger side bolt goes through into the oil, and the bolt had weakened threads and had to be replaced, not just tightened. My question/recommendation would be to drill holes into the cross member to allow easy access to the two bolts for removal of the bolts without disassembly of the support and cross-member. I think the cross-member is strong enough with two holes to access the tranny bolts. Has anyone tried this? Recommendations?
  1. Oil Leak.
    By Beltfed Only in forum Stock Tech
    Last Post: February 26th, 2009, 12:01 AM
  2. Oil leak
    By Beltfed Only in forum Open Discussion
    Last Post: January 16th, 2009, 02:15 PM
  3. Oil Leak.
    Last Post: December 1st, 2008, 12:54 PM
  4. What is this leak?
    Last Post: November 6th, 2008, 01:07 AM
