Results 1 to 5 of 5
Thread: Blackout Light Bracket drawing help
    Jan 2007
    China Lake Naval Base, SoCal
    Default Blackout Light Bracket drawing help
    On another thread I saw a couple versions of a drawing for the black out light bracket.
    I've tried to create one of my own, but may be misunderstanding the information. I'm also missing the hole size, guessed 7/16 diameter.
    any other input would be helpful to finish the drawing.
    Go Ahead, Make my day
    Which hole are you looking for? And other info? Be glad to measure for you if I can.
    Wow, nice drawing. I think I like it better than Binford's sketch on the cocktail napkin. I'm sorry that I cannot supply the hole diameters to help complete the fine work.
    Just kidding Binford...take it easy.
    The ones on the edges, 4 each, are 9/32nds.
    The ones on top, on the flat, 3 each, are 3/8ths.
    Jan 2007
    I used 7/16 for the three holes, I can change them and repost it for ppl. I think everything else is good enough to build from. The angles are rough from Brute's sketch, but if you use the thinner 16ga material they could be modified by hand.
  1. Another 12v blackout hood light conversion
    By randyscycle in forum Modified Tech
    Last Post: March 3rd, 2021, 06:41 AM
  2. Blackout light hood bracket tech
    By migz in forum Stock Tech
    Last Post: October 24th, 2011, 01:44 PM
  3. binfordm715 : Blackout Driving Light base mount
    Last Post: November 11th, 2009, 05:48 AM
  4. Blackout stop light.
    By KsM715 in forum Stock Tech
    Last Post: March 30th, 2009, 09:53 AM
  5. Where to mount my Blackout light
    By fisherman in forum Stock Tech
    Last Post: April 4th, 2008, 08:33 PM
