  #91
Old December 1st, 2018, 03:31 PM
TXfirefighter is a Soldier
Got the cylinder bracket welded together, cylinder mounted on the tubing bender, then checked the stroke again... the luck! It's about 2" too short
So, back to the drawing board...
Sent from my SAMSUNG-SM-G890A using Tapatalk
  #92
Old December 2nd, 2018, 04:13 AM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
Quote:
Originally Posted by venominjected View Post
wish me luck... I'm hanging the 205 off the back of the ZF without any support. Mine is a street queen so I hope it survives without ripping off the tail housing.
There are a couple companies that make a nice output shaft mount kit that shouln't bee to hard to incorporate...Trail tech fab here in CT (on pirate) and NWF in BC come to mind....
http://www.northwestfab.com/NP205_c_916.html
Is that real money?
  #93
Old December 11th, 2018, 02:56 AM
Sipos Sipos is offline
Civilian
Sipos is a Soldier
Are both of those companies spot on when it comes to quality, Ray? I'm in need of a shaft mount kit as well.
  #94
Old December 11th, 2018, 12:01 PM
venominjected's Avatar
Corporal
venominjected is a Soldier
I have the original NP200 parking brake system graphed onto my married NP205 so not an option
1967 M715, 6BT, ZFS542, NP205
  #95
Old December 11th, 2018, 05:53 PM
Private 1st Class
Trail tech makes this too and there are pto cover mounts as well....
https://www.ebay.com/itm/NP-205-Rear...AAAOxyHIlTcLM9
Is that real money?
  #96
Old December 11th, 2018, 05:55 PM
Private 1st Class
Quote:
Everything I have seen has been....
PTO mount
https://www.ebay.com/itm/NP-203-205-...kAAMXQeW5TcLBX
Is that real money?
  #97
Old December 12th, 2018, 12:23 PM
Waiting on parts for the bender since the cylinder stroke wasn't long enough.
I had decided the engine and trans mounts were to low and want to raise it 1 1/2". I also want the mounts to tie the frame rails together. So, after lots of measuring, designing and drawing I put my ideas on metal and started cutting. Right now I have the front and rear plates of the crossmember cut out and this weekend I'll start boxing it up.
  #98
Old December 12th, 2018, 04:54 PM
jhartings is a Soldier
Nice! Keep em coming.
  #99
Old December 13th, 2018, 07:35 AM
78FordF150 78FordF150 is offline
Basic Trainee
78FordF150 is a Soldier
Have you figured out how to mount the hydraulic master cylinder for the ZF-5 speed yet? I wanting to install one in mine and not sure how to get the correct peddle throw for it.
Sent from my SM-G930P using Tapatalk
  #100
Old December 15th, 2018, 04:21 PM
I'll be using an '85 - '90 F-150 clutch master cylinder that bolts to the firewall. Setting the stroke length will be adjusted with mounting height. I've got to pick 1 up first so I can get measurements.
I found the McLeod clutches makes a hydraulic hose with the fitting that matches the QD fitting ford uses and Russell performance makes a fitting that will go into the master cylinder and adapt it to 3 AN.
1998 - 2019
Copyright 1998-2019
