  #101
Old January 5th, 2019, 09:02 AM
TXfirefighter is a Soldier
Ok, so I'm kinda struggling with making the mounts/crossmembers that support the transmission and transfer case.
It's a ford ZF 5 spd with an ORD low range box and NP205 transfer case.
The trans has a rear mount and the ORD box has a mount plate. Getting around the front t-case output is the challenge.
I've attached pics of what I've done so far but, I'm open to suggestions.
Currently there is a plate between the trans and t-case mounts connecting them. I made a crossmember from 1- 1/4" squate tubing and arched it over the front drive shaft. It is planned to weld this to the plate.
Then I have bent up a second support that will wrap under the front yoke and weld to the bottom of the plate( this is not in the picture) along with a second rear support for the right side.
All frame attachments have poly bushing to allow for some flex.
Sent from my SAMSUNG-SM-G890A using Tapatalk
  #102
Old January 5th, 2019, 09:18 AM
78FordF150 78FordF150 is offline
Basic Trainee
78FordF150 is a Soldier
Have you thought about using a plate mount that goes on the back side of your NP205?
Sent from my SM-G930P using Tapatalk
  #103
Old January 5th, 2019, 10:12 AM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
I made a T/C mount that used the PTO port in my NP205.
  #104
Old January 5th, 2019, 02:34 PM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
Why not dip under the front driveshaft?Seems like that would be easier.....I have a PTO mount as well and a mount off or the rear cover....
Is that real money?
  #105
Old January 5th, 2019, 08:19 PM
Quote:
I don't want to interfere with driveshaft drop when the front left tire drops away.
My goal is to make Easter Jeep Rally on 2020.
  #106
Old January 5th, 2019, 08:20 PM
I'm really liking this.
Is the plate something you made or purchased?
  #107
Old January 6th, 2019, 01:47 AM
Basic Trainee
I didn't make it, as it is something you can buy. I have a couple friends that run similar setups on there rock buggies. Google NP205 mounting plate as there is a few different companies making them.
https://www.totalmetalinnovations.co...case-mount.htm
  #108
Old January 8th, 2019, 06:44 AM
Thanks! I found them and it's ordered
  #109
Old January 8th, 2019, 07:30 AM
Basic Trainee
If you haven't discovered Ruff Stuff Specialties, they sell all kinds of DIY fab parts that are really high quality stuff. I'm running several of there fab parts on my CJ7.
  #110
Old January 8th, 2019, 12:51 PM
Yep, I have bought quite a bit of stuff from them
1998 - 2019
Copyright 1998-2019
