  #111
Old January 9th, 2019, 04:03 PM
TXfirefighter is a Soldier
Think I figured it out!
And it's only 1 3/4" below the frame.
Sent from my SAMSUNG-SM-G890A using Tapatalk
  #112
Old January 10th, 2019, 03:51 AM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
There you go and it looks like you can still get in there and grease the joint.
Is that real money?
  #113
Old January 18th, 2019, 04:55 PM
Got the engine mount/ crossmember completed and welded in. It just took yo-yoing the cab on and off about 6 times.
I had to tweek the trans crossmember mount some because with all the cab jostling the engine had slid back about an inch. Sure glad I didn't rush welding in the engine crossmember!
So, the cab is back on and everything has good clearance.
  #114
Old March 13th, 2019, 04:56 PM
THANKS to 78FordF150 I'm now happy with the second t-case crossmember and support!
Tomwoods driveshafts came in and fit Perfectly
I got the hydro assist cylinder mount built and the cylinder installed (I know, the cylinder tie rod clamp isn't centered yet) and discovered my steering gear box may be too close and cause interference between the drag link and tie rod. I'll figure that out soon.
But, still moving forward some...
  #115
Old March 13th, 2019, 05:19 PM
78FordF150 78FordF150 is offline
Basic Trainee
78FordF150 is a Soldier
Glad I was able to help. I must say those crossmembers turned out pretty slick.
Sent from my SM-G930P using Tapatalk
  #116
Old April 15th, 2019, 07:42 PM
Moving forward somemore...
I got all the brake hardlines made and installed a proportioning valve along with the brake switch.
Fuel tank is upgraded to the in-tank EFI fuel pump and I'll have the fuel hardlines and hoses in this week.
I had to remove and rebuild the steering box mount because it was to far rearward and stacked the draglink over the tie rod.
Hydro-assist mount rebuilt and the cylinder all plumbed to the steering box.
SHEW WE!
But happy to be getting things moving again!
  #117
Old April 15th, 2019, 09:41 PM
Flingarrows's Avatar
Flingarrows Flingarrows is offline
Sergeant
Flingarrows is a Soldier
Nice progress
Thanks, George
Joshua 24:15
  #118
Old April 24th, 2019, 05:07 PM
Hydroboost and P/S plumbing done.
Let the wiring begin!!!
Plus the triple stick shifter from JB Fab came in.
  #119
Old May 5th, 2019, 09:56 AM
Default wiring
WOW!
This will make your head hurt!
I am retaining the 3 lever headlight switch, B/O lights and military T/S switch so splicing them into an aftermarket wiring harness is, let's say, taxing...
I'm also going to run a Holley Sniper EFI so I have that wiring to deal with too.
Then I have front and rear winches that I want to be able to control from the cab AND from each end of the truck with the normal winch control lead.
Fuel sender and fuel pump, extra battery mounted at the rear winch and add in some LED offroad lighting....
I've got to get all the circuits made and I'll add a spare wire or two then loom it all up.
  #120
Old May 5th, 2019, 02:09 PM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Holy crap. That's a boat load of mixed wiring to blend together. Turducken wiring harness.
1998 - 2019
Copyright 1998-2019
