  #51
Old February 11th, 2017, 05:13 PM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
That looks great. Nice work.
  #52
Old February 17th, 2017, 03:56 AM
JimmieM725's Avatar
JimmieM725 JimmieM725 is offline
JimmieM725 is a Soldier
looks good.
Now I see why you had to move the mounts, that tranny, it doesn`t have the drop of a normal tranny and bell housing.
I re measured my engine(300) and 230 about 6 times and couldn`t find a significant difference till I saw the latest pics. Life put my swap on temp hold.
  #53
Old February 18th, 2017, 06:30 PM
TXfirefighter is a Soldier
I wish the engine mounts were cleaner in design but I only have a regular manual press to bend the flat steel so... Kind looks rounded. But, they are plenty strong and should pose no trouble. I cut the slotted engine mount holes in them to make lifting the engine out a snap.
I've got to clean up and cap off the T-case mounts. I got the body sat down on the frame with CJ-5 bushings and everything is clearing nicely. Now my son is bugging me to get the header panel and fenders back on it.... Youngsters, they are so impatient!
  #54
Old February 18th, 2017, 06:34 PM
Quote:
Originally Posted by JimmieM725 View Post
looks good.
The trans is a ZF 5 spd. It's going to present a challenge to make brackets for the twin stick NP 205 thats behind it.... BUT, I think I have it figured out. I'll use the shifter housing mounting bolts as a pattern and make a plate to bolt down. I'm going to use solid round stock and run it from the passenger side to the drivers side (for the Ford T-Case) so the sticks are still on the right side of the trans tunnel.
  #55
Old March 29th, 2017, 06:38 PM
Had to build engine mounts 3 times until I got it sitting where I wanted it.
Testing sheetmetal to see what else I need to plan on.
Sent from my SAMSUNG-SM-G890A using Tapatalk
  #56
Old March 30th, 2017, 12:44 PM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Sweet! Looks like a truck again.
  #57
Old March 30th, 2017, 05:11 PM
Barrman's Avatar
Chief 9-flats
I like that transfer case mount.
  #58
Old March 31st, 2017, 02:44 AM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
How much do you think it pushed the tcase back? Iam doing a 6.0 NV4500, and I am wondering where I am going to end up with tcase vs. bed toolbox fitment....Looking Good!
Is that real money?
  #59
Old March 31st, 2017, 07:08 AM
Barrman's Avatar
Chief 9-flats
The bed tool box isn't the problem unless you moved back a bunch. The hump in the floor is your first issue if you move the transfer case back. Then the several inches the back of the cab hangs down below the floor is your next obstacle. Finally, you get to the bed tool box being in the way.
  #60
Old March 31st, 2017, 12:50 PM
Quote:
Playing with my JD-squared bender
1998 - 2019
Copyright 1998-2019
