Old August 2nd, 2018, 01:59 PM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
Default LED headlights
I've been resisting putting LED headlights in my FSJs because they tend to look like bug eyes, but I'd love to have better illumination.
These also have the advantage of drawing about half the amps, with current inevitably increasing when going from 24V to 12V. This is only made worse by limitations of the stock light switch.
Great info here:
http://www.fsjnetwork.com/forum/view...p?f=10&t=14299
Old August 3rd, 2018, 05:58 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
I have been looking at LED for all of my round eye vehicles. $300 for light bulbs just doesn't seem right. Then, as you pointed out there is the look when the lights are off. Thanks for posting a little bit lower cost and much better looking alternative.
I will go down the lens designed for H4 versus LED light rabbit hole today I guess.
Old August 3rd, 2018, 09:38 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
As for the voltage, 24 vs 12, you could rewire your headlights to be in series connected instead of parallel and then use 12volt LED headlights.
Old August 3rd, 2018, 11:08 PM
brycer1968's Avatar
brycer1968 brycer1968 is offline
Private 1st Class
brycer1968 is a Soldier
Default H4 conversion lenses
I installed these same Hella H4 lenses in my M725 factory headlight frames. I elected to run relays, large 150watt halogen bulbs and fed them with 12 ga wire.
The light output is now fantastic. The Hella's I got have a small DRL bulb as well, which I wired up to run when ever the engine is running
I recall that the bulb holder on those H4 lenses wouldn't clear the sheetmetal bracket that holds the back side of the lenses into the headlight body. I trimmed the metal with tin snips to allow that. I know I have pics of that here somewhere.
Bryce
1969 M725 ambulance
Old August 4th, 2018, 08:17 PM
TJinSD's Avatar
TJinSD TJinSD is offline
Basic Trainee
TJinSD is a Soldier
Default H4 replacements, 24V
Hey Barrman, have you seen these? https://thosemilitaryguys.com/produc...-approved-pair I haven't had a chance to go down the road with them yet, so I can't say much about them other than they are bright!
1968 M-715 stock w/1100R16s on Stockton wheels
  #6
Old August 5th, 2018, 10:48 AM
Barrman's Avatar
Chief 9-flats
I had not seen that add. It doesnít say LED though. Iím to the point that my vehicles that reglarly travel at more than 55 mph have sylvania silver star halogen bulbs.
They were a huge improvement over the regular halogen bulbs. However, they degrade over time and are starting to look dim. Especially compared to newer vehicles next to me in traffic when driving where there arenít street lights. Replacement is going to around $50 for a set just to repeat in another 4 or 5 years.
HID lights have always been a no go for me because my 30 plus year old vehicle wiring systems couldnít do it.
Trucklite LED purpose built bulbs are a bit over $300 a set. I havenít wanted to make that investment just yet. Plus they look like something from some sci-fi movie.
The JK Jeep forums are full of pretty opinionated threads about putting LED bulbs in the stock factory H4 headlight lenses. Most give the impression it doesnít work well without replacing the lense with one meant for LED bulbs. Back to the $300 admission price.
That $300 gets you plastic lenses. Which besides the cost has been my biggest reason not to get into the LED world. Plastic lenses around here last just a year or so before they cloud up and become useless.
This thread is about glass lenses with none of the links mentioning lack of light focus or anything about problems getting good light patterns down road. All good. Plus, about 1/3 the price of the purpose built ones. Yes, that is still double my current light cost. But I might make the plunge after some more research into light patterns. I havenít found any negatives yet.
  #7
Old August 5th, 2018, 11:14 AM
TJinSD's Avatar
Basic Trainee
TJinSD is a Soldier
I'm with you on all points. I don't like the look of the LED lights for this vehicle. I never considered what affect the lens would have on light patterns. I'm hoping someone above my pay grade figured that out.
The main reasons I got these is because they are glass, are 24V halogen, and the wiring adapter plugs into the stock harness. If I find a 24V set of Silver Star bulbs that fit they will go in immediately! They are my go-to bulbs as well, not just for going fast, but for 2 lane (or less) side vision too.
  #8
Old August 16th, 2018, 11:15 AM
jeeper's Avatar
jeeper jeeper is offline
Sergeant
jeeper is a Soldier
Good timing for this thread. I just sent back some LED headlights I bought for my Wrangler/Cj project. They were pretty bad in my opinion.
I just ordered the Hella housings. I should get them tomorrow I think. I'll report back with how they function once I've had a chance to test them out. I will be using Halogen bulbs to test them with at first because I already have them but will be trying the Hikari LEDs once I am comfortable with the Hellas performance with what they were designed for initially.
I bought the military Truck-lites for my second M715. I was a bit disappointed in them. I thought the Chinese knock off JW Speakers I bought for my TJ were better and were less than half the price.
  #9
Old August 20th, 2018, 04:03 PM
JimmieM725's Avatar
JimmieM725 JimmieM725 is offline
JimmieM725 is a Soldier
the last led`s I bought said 8v to 30v. octane lighting calif.
  #10
Old October 13th, 2018, 04:44 PM
jeeper's Avatar
Sergeant
jeeper is a Soldier
I guess I forgot to report back on this. I did end up testing the Hella housing I bought from here. When I bought them they were $27 for the pair and have a daytime running light that I may actually wire in some day.
I tested them with some cheap halogen lamps and was pretty disappointed. I was actually going to send them back but I decided before I did that I'd try them with these LED bulbs. The bulbs were $32.99 for the pair.
They work great together. I'd say they are a good improvement over stock sealed beam lights. And they are reasonably priced.
I didn't take any pictures but it is hard to show the improvement with a picture anyway. You really need to see them in person to appreciate how much better they are than stock.
1998 - 2019
Copyright 1998-2019
