Old February 28th, 2019, 03:08 PM
WillyRod WillyRod is offline
Civilian
WillyRod is a Soldier
Default Cummins 6bt ratio gears??
Hello, new here from Arkansas!!
Looking to do a Cummins 6bt with stock ratio gears 5.38
Running 900-16 tires.
Old February 28th, 2019, 05:36 PM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
Welcome.
You want to be at around 1700-1900 RPM at the speeds you'll be driving the most. Below that, you'll lug the engine. Above that, your fuel consumption will climb very quickly.
A handy gearing calculator:
http://4lo.com/calc/gearratio.php
Old March 1st, 2019, 02:46 AM
glenn glenn is offline
Sergeant
glenn is a Soldier
Stock ratio should be 5.87. I think you will find you will need to change axles to get better gearing to run 900x16 tires.
1998 - 2019
Copyright 1998-2019
