Old March 13th, 2019, 11:47 AM
Tobcotton's Avatar
Tobcotton Tobcotton is offline
Basic Trainee
Tobcotton is a Soldier
Default Headlight Help
I'm trying to put together a headlight assembly but I believe I'm missing some small parts. I have looked at the headlight assembly diagram in the manual but it is not detained enough. I can't make out the detail, springs, screws or mounts that hold it all together. I have #6 & 7 and the two shaded housing pieces the light goes in. I need a few pictures of the fasteners, clips or screws that hold everything.
Old March 13th, 2019, 12:05 PM
Tobcotton's Avatar
Basic Trainee
Old March 14th, 2019, 04:34 PM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
I am putting a set together myself. You need the two springs, adjustment screws and the little flat slide able pieces the adjustment screws screw into. I used a set of m35 light buckets for the adjustment screws and slide pieces.
A set of early Jeep light buckets donated the springs.
I donít have any junkyard near me. If you do, I suggest taking a walk and looking at the buckets you find.
1998 - 2019
Copyright 1998-2019
