Results 1 to 4 of 4
Thread: rip68 : 6.2 L Deisel in a M715
    Default rip68 : 6.2 L Deisel in a M715
    Post by rip68 on Jun 25, 2006, 3:51pm
    Has anyone put a 6.2 liter deisel in a M715?
    If so, how does it fit?
    What are the issues including motor mount fab?
    Default bigwheelbob :
    Re: 6.2 L Deisel in a M715
    Post by bigwheelbob on Jun 25, 2006, 5:18pm
    Spicer has one in one of his trucks, I am sure it is fine as long as you dont expect to spin the tires, LOL.
    Default barrman :
    Post by barrman on Jun 25, 2006, 7:51pm
    Oilcan ran his 6.2 M715 all over WITC at the FE last week. Poolmike is putting one in his as well. I know there are other, but can't remembr them all.
    Basically, they are as easy to fit as a gas V8. I used a 1/4" steel plate to go from the 3 motor mount holes on the block of my 396 to the stock 230 rubber motor mounts. Many others have done the same.
    Late 60-early 70's Chevy truck and I think Chevelle motor mounts fit the stock frame horns almost perfectly too.
    Default oilcan :
    Post by oilcan on Jun 25, 2006, 8:21pm
    The basic spicergear motor mount plates are all I used to drop the system in place. I had to chop up the trans cover 'cause the shift tower moved forward a bit, but overall, it was an easy swap. Same as SBC.
    By the way, the power difference between open exhaust and 2" straight duals is really noticable. The glasspacks didn't make much difference. When I go through the truck again, I'm gonna try to get 3" duals crammed in there somewhere.
  1. rip68 : Bob Cowan weld fix for drill holes
    Last Post: December 15th, 2009, 08:16 PM
  2. rip68 : Plug Wire Problem
    Last Post: December 15th, 2009, 03:11 PM
  3. rip68 : Length Of Oak Slats For Troop Seats?
    Last Post: November 11th, 2009, 04:05 AM
  4. rip68 : Need a good brand of paint stripper
    Last Post: November 11th, 2009, 01:19 AM
