Old November 11th, 2009, 03:09 AM
Elohim1 Elohim1 is offline
Elohim1 is a Soldier
Default elohim1 : What is the spacing on the points for a 230?
Post by elohim1 on Jul 22, 2006, 9:24pm
Changed my points and need to know where to set them.
Also my old points had an extra copper spring on it. It had the steel spring also.
My new points I got from AB linn only had the steel spring ?
LuckyPabst's Avatar
LuckyPabst LuckyPabst is offline
Private 1st Class
LuckyPabst is a Soldier
Default luckypabst :
Re: What is the spacing on the points for a 230?
Post by luckypabst on Jul 22, 2006, 10:15pm
The copper is used as the current path. It's not actually a spring. It seems they did away with the separate conductor in newer points sets, my guess is to save on manufacturing costs.
Chris
Default elohim1 :
Post by elohim1 on Jul 23, 2006, 8:02am
Anyone know how much gap on the points?
Thanks for the info. luckypabst.
Moderator
PseudoZone is a Soldier
Default wetcj :
Post by wetcj on Jul 23, 2006, 8:50am
.020, plus or minus .002
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Post by brute4c on Jul 23, 2006, 11:34pm
Yep, .020 + or - .002 inch OR 41 degrees of dwell...take your pick.
On the dwell, the manual states that 38 to 44 is acceptable....less than 38, large gap, may cause engine to misfire at high speeds or under load....less than 44, small gap, can cause hard starting.
HTML code is On
gregolma715 : Points PseudoZone PseudoZone - Open Archive 3 November 11th, 2009 03:44 AM
Swapping points to hei gimpyrobb Modified Tech 5 May 12th, 2008 01:51 PM
Points and Condenser for Stock Distributor rboltz Stock Tech 1 December 22nd, 2007 06:01 PM
Back spacing question Ricky Stock Tech 9 February 10th, 2007 09:18 PM
Points & Dwell law Stock Tech Archives 1 March 1st, 2004 08:04 AM
