Old November 12th, 2009, 01:27 AM
Moderator
PseudoZone is a Soldier
Default mthomsen : LU4 winch/ paint removal
Post by mthomsen on Sept 21, 2006, 10:16pm
What is the best way to clean paint off of the aluminum? I was thinking of sand blasting it, but will it hurt the cast aluminum? Or wound a paint stripper be better? Planning on repainting it od green. It is all disassembled.
fisherman's Avatar
Sergeant
fisherman is a Soldier
Default fisherman :
Re: LU4 winch/ paint removal
Post by fisherman on Sept 21, 2006, 10:28pm
Sand blast away, the etching of the metal will help hold your new paint really good. After sand blasting give the parts a good bath, clean with brake klean, let dry. Paint really good.
Moderator
Default robertcowan :
Post by robertcowan on Sept 21, 2006, 11:29pm
BETTER USE ALUMINUM METAL PREP B4 YOU PAINT ALUMINUM.TO CLEAN IT.
Moderator
Default thetroublemaster :
Post by thetroublemaster on Sept 22, 2006, 5:38pm
I used aircraft stripper. A couple coats, 3-5 beers, scraping, 2-3 more beers, more coats of stripper, scrape and wire brush and a good wash afterwards. It really didn't take that long.
HTML code is On
Paint removal and engine mount question dlmos Modified Tech 6 February 16th, 2010 03:33 PM
mthomsen : Gillespie 24052 paint??? PseudoZone PseudoZone - Stock Tech Archive 3 December 15th, 2009 01:20 PM
mthomsen : wheelbase PseudoZone PseudoZone - Stock Tech Archive 1 December 15th, 2009 01:01 PM
Show me your winch (BUILT) winch bumpers bluesman2a Modified Tech 26 June 21st, 2009 11:45 AM
Paint Removal ffdemoss Modified Tech 6 February 20th, 2008 02:51 PM
