Old February 27th, 2008, 09:35 PM
mattman002 mattman002 is offline
New Recruit
mattman002 is a Soldier
Default Brake Line Adapter Questions
I'm replacing the brake line from the master cylinder to the brake switch with a braided line and was wondering if anyone knew the thread size/count for the male ends that go into the master cylinder and brake switch.
Old February 27th, 2008, 10:03 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
I believe the brake lines are standard 3/16ths brake line and so the fittings on the ends of one of those lines would be the ones you need...sorry I dont know the count and all off hand...someone else may.
Old February 27th, 2008, 10:31 PM
LuckyPabst's Avatar
LuckyPabst LuckyPabst is offline
Private 1st Class
LuckyPabst is a Soldier
3/8-24 IFM, both ends.
Old February 28th, 2008, 07:53 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
I am not sure, but I think there is some kind of DOT rule about having metal lines from the MC as far as you can go. Then the flexible lines at the rear axle and each front corner. The idea being that any flexible line is going to flex some. That flex will do several things. Make a pedal spongy and eventually wear out the flexible line are two I can think of right away.
With a stock engine you don't have to worry about heat, but a V8 will make a lot of heat near the line from the MC to the switch block. That could cause shortened life and possible brake fluid boiling.
That was the safety warning. I personally don't see anything wrong with it as long as you use quality parts and do it right. If your state has inspections though you might run into trouble. Something else to check on I guess.
Old February 28th, 2008, 10:05 AM
New Recruit
Thanks for all the help and suggestions. I hope to possibly be tackling the brakes this weekend or the next. Thanks again
Brake line diameter?? DivingKaiser Modified Tech 1 April 6th, 2010 05:23 AM
fisherman : Brake line pressure switch for brake lights. fisherman PseudoZone - Open Archive 12 November 11th, 2009 10:33 PM
Brake Line Tools Tomahawk715 Modified Tech 10 November 1st, 2009 10:01 PM
Brake Line Problem? fisherman Modified Tech 14 October 2nd, 2007 08:13 AM
brake line to master cyl. ?? Elohim1 Modified Tech 4 February 8th, 2007 10:00 PM
