Old June 8th, 2008, 08:41 PM
dave's Avatar
dave dave is offline
Private 1st Class
dave is an Observer
Default front hubs? need info!
what is the correct grease for the front hub bearings? I pulled off the plate to replace the lockouts and on the pass. side. it has what looked like rusty wheel bearing grease, gritty, and on the drivers side there was what would be no more than axle grease in it. what is supposed to be in it? Im hauling it to Co. and dont need any problems so as im there new wheel cyl's and all are in order along with bearings and seals. thanks in advance.
67 M725, 67 M715, 68 M715
Old June 8th, 2008, 09:54 PM
Binford's Avatar
Binford Binford is offline
Moderator
Binford is a Soldier
I don't know that there's really any "incorrect" grease you could use. Any general wheel bearing grease ought to do you fine. I use Lucas Xtra Heavy Duty grease for mine.
From: http://www.lucasoil.com/products/dis...tid=2&loc=show
Lucas X-tra Heavy Duty Grease
Virtually wash-out proof. Stands up to high temperatures and stays soft in very low temperatures. EP fortified and exceeds OEM specifications.
Lucas X-Tra Heavy Duty Grease was formulated for automotive, agricultural, heavy-duty and industrial applications. It is virtually waterproof and is more stable than all conventional lithium grease. It is fortified with an extreme pressure additive package and it exceeds OEM Lube for Life specifications.
Key Benefits
* Lasts four times longer than regular grease
* Virtually waterproof
* All temperature stable
* Exceeds Lube for Life specifications
* The ultimate grease for high speed bearings
Not that any bearing in an M715 would be "high speed!" Heh, heh, heh....
-- Tim Taylor
Last edited by Binford; June 8th, 2008 at 09:58 PM. Reason: Added a chuckle at the end....
Old June 9th, 2008, 07:46 AM
gimpyrobb's Avatar
gimpyrobb gimpyrobb is offline
Sergeant
gimpyrobb is a Soldier
Tim, you can pull a 715 alot faster than it will drive. We hit some high speeds on the way to W.I.T.C. a couple years ago.
Old June 9th, 2008, 08:32 AM
Binford's Avatar
Moderator
Good point. So you would agree that Lucas X-tra Heavy Duty Grease would be a good choice for that, eh? But I posted that more for the chuckle than anything else!
-- Tim Taylor
Old June 9th, 2008, 03:34 PM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Dave, normal wheel bearing grease will work fine. The water proof boat trailer stuff isn't really needed if you sealed the lock out hubs on right.
Don't try to run the CO speed limit on I-70 of 80 mph either. Besides sucking gas like crazy, 60-65 and new grease will keep your M715 happy.
  #6
Old June 9th, 2008, 03:56 PM
Binford's Avatar
Moderator
True, but waterproof grease for the hubs/wheel bearings is just a habit from my CJ driving. We have a lot of puddles and creeks to cross along mountain trails and it's just plain hard to keep the water sealed out. I appreciate the extra protection a waterproof grease offers.
-- Tim Taylor
  #7
Old June 9th, 2008, 04:24 PM
Barrman's Avatar
Chief 9-flats
No doubt the water proof stuff is better. However, the lube order just calls for wheel bearing grease of the standard type. So, I just tried to pass on to Dave that the stuff he uses on all the vehicles he works on will be just fine on his ice cream truck.
  #8
Old June 9th, 2008, 04:31 PM
Binford's Avatar
Moderator
Quote:
So seconded!
-- Tim Taylor
  #9
Old June 10th, 2008, 04:14 PM
dave's Avatar
Private 1st Class
dave is an Observer
thanks guys! ill use lucus both sides looked more like 90 weight gear oil than grease but the left side looked pretty bad.
robertcowan : FRONT 8 LUG HUBS THAT FIT THE M715 FRONT AXLE PseudoZone PseudoZone - Mod Tech Archive 24 December 15th, 2009 06:14 PM
winch hubs kevbo Stock Tech 5 July 17th, 2009 05:54 PM
front lock out hubs dave Modified Tech 12 May 30th, 2008 07:12 PM
How get into front Hubs and Pull rear Diff? HUMMER103 Modified Tech 10 February 6th, 2008 01:43 PM
Locking Hubs CSG1948 Open Discussion 4 January 10th, 2008 07:15 PM
