Results 1 to 6 of 6
Thread: ford 300
    Nov 2009
    Bridgton, Maine
    Default ford 300
    has anyone ever heard of putting a ford 300 ci in a 715 and if so what are the pros and cons
    thanks guys
    Luckypabst out in CA has done this and kept the FI. Awesome. Plenty of power and reliability. It is the motor they should have originally gone with. That being said I went with a v8 for real power.
    Aug 2007
    central central wisconsin
    I had seen an article in a 4X4 magazine about ten years ago that featured an M715 with the Ford 300 and the writer of the article had said that it was the most original looking motor that you could have installed into this truck. It does have about the same dimmensions as the 230. The one in the truck was carburated, but It would be very easy to swap in an entire wiring harness from the donor truck to upgrade to fuel injection and have 12 volts too. I would suggest swapping in a Ford T-18 at the same time so that you don't need any adapter.
    Im putting a 300 in my 715 but I went with np435 instead of the t18. The 300 fit perfectly using stock motor mounts. The tranny sits almost in the stock location and should not require many modifications. That is all I can tell you at this point because thats as far as I have gotten.
    352 series Chelsea PTO can be installed on the np435's passenger side. Could it be rotated to the rear for a under the bed mounted PTO? Cross member may block PTO drive?
    Nov 2009
    Bridgton, Maine
    thank guys i am happy to have a site were i can go and find answers to my questions not more questions you guys are great
  1. What does it take to ford?
    By buzzbike71 in forum Stock Tech
    Last Post: May 22nd, 2011, 12:35 PM
  2. ford 300 help
    By FullBird in forum Modified Tech
    Last Post: July 18th, 2009, 04:59 PM
  3. Ford 300
    By CTM in forum Modified Tech
    Last Post: January 11th, 2009, 07:38 PM
  4. what does it take to put a ford 390 in a 715
    By 05strokinfx4 in forum Modified Tech Archives
    Last Post: May 9th, 2004, 09:10 PM
