Results 1 to 4 of 4
Thread: pinion seal?
    Default pinion seal?
    I did a search but nothing turned up. Does Napa have a pinion seals for the stock front end. Does anybody know the part number? or what other d60 seal will work in it.
    -Ty
    Dont know of a Napa number...I have this if it helps:
    Federal stock number: 2530-9286149
    Manufacturers part number: 65909-945710
    thanks, see if I can track one down
    I'm in the same boat, except I'm needing a rear pinion seal and a diff cover gasket.
    Tony Casey
    BULLGEARInc.com
  1. Pinion Markings
    By Pineyguy in forum Open Discussion
    Last Post: January 1st, 2010, 02:41 PM
  2. Pinion seals
    By Hetzer in forum Stock Tech
    Last Post: October 5th, 2009, 09:53 PM
  3. Ring and pinion questions
    By fng in forum Modified Tech
    Last Post: March 18th, 2007, 06:56 PM
  4. Need a rear axle pinion nut.
    By TheWarTapes in forum Stock Tech
    Last Post: March 6th, 2007, 08:10 PM
  5. Ring+ Pinion?
    By poolmike in forum Modified Tech Archives
    Last Post: May 10th, 2004, 11:24 PM
