Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: This is what 'Disaster Averted' looks like
    Understand. I will NOT be cutting a hole in the firewall. Some have suggested, remove the engine mounts and allow the engine to slightly fall forward, giving more room.
    Thanks for reminding me. I had forgotten...
    Hey friend,
    After some snooping for an aggressive oil leak with no loss in pressure, I discovered the same this past weekend. Is there any way to change this without taking the engine out or lifting the cab? Very appreciative of your time.
    Monty, Somerset, KY
    I have an access panel in the firewall of my truck. It's hidden behind the heater on the inside, and behind the engine (naturally) outside. That made it very easy to access the top connection. However, if I didn't have that, I *think* that I would have removed the valve cover and tried to loosen the hose with a crowsfoot wrench on an extension. Maybe someone else has tried this and can comment on if it would actually work.
    Also, see Don's idea above. That sounds like it would work, but it's more work. And maybe the fan should also be removed before doing that?
