Results 11 to 20 of 22
Thread: bigkev : installation of fording kit
  1. #11
    Port Orchard, Wash.
    Default binfordm715 :
    Re: installation of fording kit
    Post by binfordm715 on Sept 5, 2006, 11:06pm
    Here's some pics showing the mounting of the snorkel and exhaust on Al's truck, in case anyone finds it helpful:
  2. #12
    Default brute4c :
    Post by brute4c on Sept 6, 2006, 9:09am
    Nice pics!!
  3. #13
    canby Oregon
    Default 503m715 :
    Post by 503m715 on Sept 6, 2006, 12:53pm
    Thanks Al and Tim.
  4. #14
    canby Oregon
    Default 503m715 :
    Post by 503m715 on Sept 6, 2006, 12:58pm
    Stanman, I think I will hang on to my fording kit for now. I am waiting for Tim to put a different motor in his truck so I can buy his stock parts. (wishful thinking) I just bought it from vpw it was about $300 including shipping.
  5. #15
    Default thetroublemaster :
    Post by thetroublemaster on Sept 6, 2006, 2:23pm
    Man I gotta quit being so distant. Thanks to Tim my truck is a celebrity now!! Actually it wasindeed Douger that made it happen. Those mirror arms are so neato! Before my truck was worth 1200.00 bucks. After installing the correct mirror arms it's worth 7500.00 now!!! LOL JK! heh heh..
    Ok my fording kit is not quite 100% correct. I don't believe the desert air cleaner was ever used with the fording kit. Not sure. Plus you have to have the govenor installed to allow enough room for the fording valve in the crankcase hose. I have been lazy and not installed mine yet. Somebody correct me if I'm wrong as I'm not positive on this stuff.
    Plus the elongated nut where the stack attaches to the windshield is not correct. Jacks Gov't surplus threw that in there to make it work. I would like to see someones truck that has the correct spacer or bushing.
  6. #16
    Default brute4c :
    Post by brute4c on Sept 6, 2006, 2:56pm
    The manual looks like there is no governor...but they do have an upper and lower crankcase hose so maybe its a different animal...well 2 different hoses altogether....
    Was yours 2 new hoses in the kit or ?
  7. #17
    Post by thetroublemaster on Sept 6, 2006, 3:20pm
    I bought both fording tubes from Jack. I have had to find everything else. I looked over the manual for it and answered one of my questions. I looked at my setup minus the gov and there was no way to fit the crankcase hose and have the fit be good. It looked to me like it needed the extra height of the gov. I have the cast air horn that goes with the hood mounted air cleaner. It was just to low for the hose hookup.
  8. #18
    canby Oregon
    Default 503m715 :
    Post by 503m715 on Sept 6, 2006, 3:56pm
    My kit did not include the governor. I read somewhere that they were only used on the later production trucks. Al where you have the nut by the windshield, I have a 2nd L-bracket for upper intake tube mount.
  9. #19
    Post by thetroublemaster on Sept 6, 2006, 4:02pm
    I saw that. Any chance you could tell me how thick the bracket is?? I can make one at home.
    As for the gov, don't listen to me... I'm probably full of it. LOL..
  10. #20
    Default brute4c :
    Post by brute4c on Sept 6, 2006, 4:09pm
    The fording kit does show that it comes with the lower and upper hose pieces....pieces 20 and 22 respectively...see image:
    So that would mean if you used the stock hose, it wouldnt fit the new setup correctly as this 2 piece setup would replace the stock 1 piece...
  1. Air Cleaner Installation help needed...
    By kyken in forum Open Discussion
    Last Post: February 19th, 2010, 09:25 AM
  2. Dash panel Removal / Installation
    By shepsjeep in forum Stock Tech
    Last Post: September 29th, 2009, 09:25 PM
  3. A/C Installation
    By Maingear in forum Modified Tech
    Last Post: June 3rd, 2009, 01:38 PM
  4. Power Steering Installation Question
    By joesco715 in forum Modified Tech
    Last Post: May 3rd, 2007, 11:25 PM
  5. help! sm465 installation.
    By bggrntrk in forum Modified Tech Archives
    Last Post: May 4th, 2004, 11:21 AM
