Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: M-715 Rockwell build question
    Default M-715 Rockwell build question
    I'm going to put 2.5 ton rocks under my truck. When doing the rear axle whould it be better to move the leaf springs from the outboard to right under the frame rail? The most lift I need is to clear a set of 44"- 45" tractor tires on leaf springs with 2.5 ton rocks! My axles are in link below, the big caliper sticks inward alot.
    C:\Documents and Settings\User\My Documents\My Pictures\Rockwell Axles '57 Willys
    Thank you.
    Brandon
    Jul 2008
    Saginaw Michigan
    I have rockwells under my truck with 46" tires. All I had to do was a springover and shackle flip to clear. My spring pearches I used are also about an inch tall. If you go through my build thread there are some pictures and a link to my photobucket page with more pics.
    Default Rockwell build
    Thanks for the reply, the only problem I have on my spring over is my rear Rockwell axle. Look in my link of my rear axle, the calipers stick out and will hit the rear springs in the outboard position. I think they will need to be moved inward and mounted on the bottom of the frame rail. Do you know anyone who has done this? If so, what lift spring if any did they use for a 44"-46" tire?
    Thanks,
    Brandon
    Brandon,
    Your picture link wont work because that is a location on your computer and none of us can get there...
    Feel free to email them to me...
    How are you...been a while!
    Default not a link
    i would like to see the pics because im thinking of going to rockwells also and would like to see how you did yours . and maybe i can help you as well but you need a link or put the pics here in your post .
    Here are the pics he sent:
    He asked this in this email:
    Do you know if these Dayton calipers are F-350 and what year they might be?
    I have no clue.
    I have done a few F350 brakes and those look like nothing I have ever seen on one. My guess would be some medium duty truck application. I like them though.
    GMC Kodiak or Top Kick trucks used the Dayton calipers. In the 2.5 to 5 ton range of trucks. Mid 90's and up.
    Thanks for the caliper info, I think I'll just send them to someone for a rebuild. You go to a local auto parts store with no info on the calipers and ask if they can tell you what they come off of, and they just look at you dumdfounded!
    Brandon
    Jan 2008
    Montreal Canada
    with the stock drum brake and the stock leafs configuration you have a tight fit. Those calipers look like to be big so probably you will have to move the rear suspension inside or at least under the frame to give you extra spaces to work with.
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
  1. Question for Rockwell Guys
    By CrashMorriss in forum Modified Tech
    Last Post: June 11th, 2009, 09:11 PM
  2. stupid rockwell question
    By rustwagon in forum Modified Tech
    Last Post: January 26th, 2009, 05:23 AM
  3. Yet another rockwell question
    Last Post: January 14th, 2009, 09:30 PM
  4. Rockwell build up
    By Nuke_spicergear in forum Modified Tech Archives
    Last Post: May 25th, 2004, 09:17 PM
  5. ROCKWELL Question
    Last Post: January 13th, 2004, 08:35 AM
