Results 1 to 10 of 15
Thread: Best Aftermarket Alternator?
    Default Best Aftermarket Alternator?
    I've seen people run 12 volt alternators on the 24 volt systems. What would be the best one to put on the truck?
    A lot of guys use the GM one wire types because they are easy to wire in and put out a good amount of amps...pretty much the same to wire up and put a belt on.
    I was thinking how a 12v alternator can charge a 24v system? (2 batterys)
    They can't. Most 12v alts are add ons for accessorys. Or the truck was converted to 12v.
    I was thinking conversion too.
    Of course theres the dual setup where there are both 12 and 24 volt alts and 3 batteries...still a conversion but not just one way or the other.
    Then how does a boat alternator (12 volt) charge the batteries for 24 and 36 volt electric trolling motor system???? I hate electrical systems......
    Maybe a system like this??????????
    http://www.cabelas.com/hprod-1/0032185.shtml
    Google 24V alternators and you will find marine alternators with this output. I've been chasing this solution for my 6.2 project with a 24V HMMWV injection pump and found the simplest solution right around the corner at a little electrical rebuild shop that took one of my 12V CUCV alternators and rebuilt it as a 24V one wire for $60. I was going to use the stock 24V alt on a HMMWV alternator mount but there wasn't enough room.
    You guys know that the newer hmmwv alts have 12v and 24v outputs right?
    Would this work?
    http://cgi.ebay.com/ebaymotors/ws/eB...8427&rd=1&rd=1
    With one wire hookup?
  1. Aftermarket Gears?
    By Skywarn in forum Modified Tech
    Last Post: January 27th, 2010, 09:52 AM
  2. Aftermarket Seats
    By ffdemoss in forum Modified Tech
    Last Post: January 8th, 2008, 08:40 AM
  3. Aftermarket Gauges?
    Last Post: March 17th, 2007, 09:29 PM
  4. Help with aftermarket rims
    By Safaritow in forum Open Discussion
    Last Post: February 1st, 2007, 01:26 PM
