Results 1 to 4 of 4
Thread: Vent System Schematic
    Mar 2007
    Carle Place, NY
    Default Vent System Schematic
    Does anyone have or know where i can see a schematic of the entire vent system including the route taken by each line and where they go from steel line to hose. thanks
    Not really....we have a chart to show the basic routing of the vent lines and which ones run together. There are 2 different versions as there was a big change during production from a carb mounted air cleaner and no governor setup to a governor equipped unit that required a canister air cleaner that bolts on brackets to the underside of the hood.
    The diagrams are in the Online Maintenance Manuals section, linked above...or directly linked here:
    Early, carb mounted aircleaner/no governor:
    http://www.m715zone.com/vb/view.php?pg=early_vent
    Late, Canister air cleaner/with governor:
    http://www.m715zone.com/vb/view.php?pg=late_vent
    Mar 2007
    Carle Place, NY
    Thanks for quick reply, but that helps very little unfortunately. Many of my steel lines are missing, and i need to know where they came from and where they go to, and the shape ect... I appreciate it - Roger
    Roger, what type of air cleaner are you running? Canister or regular. If canister, I'll go out to my truck with a camera and take some pics for you. If non-canister, I can't be of much help.
    Zach
  1. Odd addition to the Vent line
    By Stkelsey in forum Stock Tech
    Last Post: March 13th, 2018, 09:33 AM
  2. dummy : Wiring Schematic?
    Last Post: November 11th, 2009, 04:28 AM
  3. CAD Wiring Schematic Created
    By rboltz in forum Stock Tech
    Last Post: March 21st, 2008, 11:44 PM
  4. Last of the vent lines
    Last Post: May 1st, 2007, 06:23 PM
  5. A/C Vent
    By Barrman in forum Modified Tech Archives
    Last Post: February 7th, 2004, 12:51 PM
