Results 1 to 10 of 10
Thread: xjchief : NP200 seals
    Default xjchief : NP200 seals
    NP200 seals
    Post by xjchief on Oct 3, 2006, 11:40am
    Getting really tired of the gear oil dripping everywhere. Anyone know of a source for a new set of seals?
    Default brute4c :
    Re: NP200 seals
    Post by brute4c on Oct 3, 2006, 11:57am
    AB Linn, Memphis Equipment, VPW, Surplus City....pretty much everone with M715 parts...
    Course those are NOS...if you want NEW ones, most of the ones from an NP205 swap I have heard...someone should be able to confirm that...
    Default barrman :
    Re: NP200 seals
    Post by barrman on Oct 3, 2006, 11:58am
    AB Linn has boxes full of them if you want the stock ones. NP205 seals from just about any '70's Ford, Dodge or Chevy will fit too. They just aren't correct.
    If you run the truck over 50 mph for any extended period of time, the seals will keep going out. Switch t-cases or drive slower if you want to stop the leaks. Also, use Permatex #2 gasket maker to seal the drain and fill plugs. Big leak stopper there.
    Default brute4c :
    Re: NP200 seals
    Post by brute4c on Oct 3, 2006, 12:32pm
    If I recall this right...the stock NP200 seals were rated for a lower temp before failure than the newer NP205 ones...I think Bob Bump posted it some time back on the failed drive...
    Seems there was like a 50 degree difference in max temp that the seal could be exposed to before failure...a significant difference...
    Default barrman :
    Re: NP200 seals
    Post by barrman on Oct 3, 2006, 12:40pm
    The stock seals have a double lip. One to keep the oil in and one to keep dust off the oil seal. The seal metal itself is deeper into the t-case. That is correct for these trucks. The NP200 seal just has the keep the oil in lip. That extra lip not being there and the new material makes a big difference in the life of the seal as pointed out above.
    2 of my 4 are NP205 type and don't leak. The old NP200 ones are seeping oil. That could be age or it could be design.
    Default xjchief :
    Re: NP200 seals
    Post by xjchief on Oct 3, 2006, 1:49pm
    Okay, the 205 seals sound like the way to go. Does some one who's swapped seals have a part number for a set of 205 seals that will interchange?
    BTW, AB just emailed back that he's got the "civilian" seals. Does the mil version have the double lip and the civi the single?
    Default barrman :
    Re: NP200 seals
    Post by barrman on Oct 3, 2006, 3:00pm
    Yes on the civilian version.
    Lone Pine, CA
    Default luckypabst :
    Re: NP200 seals
    Post by luckypabst on Oct 3, 2006, 7:41pm
    I pulled the old ones from Frapguys Tcase and called the number in to the local auto parts store. No problem getting replacements of new manufacture. I didn't save the part number however so I can't help there.
    All 4 re-leaked in short order and the next step is a redi-sleeve but those are like 30 bucks each and not worth it for a case that'll get ditched soon anyhow.
    No reason to get things like grease seals from the surplus suppliers if you can get the same in new manufacture locally.
    Chris
    Default xjchief :
    Re: NP200 seals
    Post by xjchief on Oct 3, 2006, 10:28pm
    This look like it will do the job?
    NEW PROCESS 205 TRANSFER CASE GASKET AND SEAL KIT
    This kit contains all the gaskets and seals to fit all of the
    New Process 205 transfer cases in the following
    1970-1991 Chevrolet 1/2 ton - 1 ton
    1969-1987 Dodge 1/2 ton - 1 ton
    1971-1989 Ford 1/2 ton - 1 ton
    Default brute4c :
    Re: NP200 seals
    Post by brute4c on Oct 4, 2006, 12:54pm
    The output seals will be right....the gaskets...I think there could be differences there...
  1. xjchief : Anybody have or seen this?
    Last Post: November 12th, 2009, 06:37 AM
  2. xjchief : M35
    Last Post: November 11th, 2009, 05:35 AM
  3. xjchief : Muffler
    Last Post: November 11th, 2009, 05:12 AM
  4. Replacing NP200 seals
    Last Post: February 14th, 2009, 10:49 AM
  5. NP200 seals?
    By Mikel in forum Stock Tech
    Last Post: February 27th, 2007, 06:50 PM
