Results 1 to 6 of 6
Thread: ih200 : Oil recommendations in 230
    Default ih200 : Oil recommendations in 230
    Post by ih200 on Jul 21, 2006, 10:11pm
    Am just curious what weight of oil I should use in the 715? I was thinking 30wt or maybe some 15w40 rotella. I know everyone has there favorite brand, but I just need to know what weight to use.
    Lone Pine, CA
    Default luckypabst :
    Re: Oil recommendations in 230
    Post by luckypabst on Jul 22, 2006, 12:41am
    Nothing special, just use what works in your climate. The dash plates give the spec, I wanna say straight 30 wt., but that's from back in the day before multi weight oils were around.
    Chris
    Default fastfrankie :
    Post by fastfrankie on Jul 22, 2006, 7:41am
    I used 20W-50 when I changed my oil in February...the truck cranked real slow with that in it...but now is fine. When I change the oil again come October, I will use something like 10W-30 for winter driving. That 20W-50 is like glue in the cold...
    If I had straight 30W I would also use that in spring and summer...
    Geneva, FL
    Blog Entries
    1
    Default teking :
    Post by teking on Jul 22, 2006, 7:46am
    i use 30W or 10W-30 year round in FL.
    Default brute4c :
    Post by brute4c on Jul 22, 2006, 9:40am
    I use 5w-30 in winter and 10W-30 in summer
    Mar 2004
    northern Arizona
    Default compexp :
    Post by compexp on Jul 22, 2006, 10:37am
    Lube order specs 30w when temp over 40* - 10w when 40* down to -10* and some special stuff below that.
    10w-30 would have you covered.
  1. ih200 : Vin Location
    Last Post: November 11th, 2009, 04:27 AM
  2. Trailer recommendations
    By porkchop in forum Open Discussion
    Last Post: August 9th, 2008, 07:27 AM
  3. Custom Rims and Size Recommendations
    By joesco715 in forum Open Discussion
    Last Post: May 6th, 2007, 12:18 PM
  4. Fluid Change Suggestions / Recommendations
    By joesco715 in forum Stock Tech
    Last Post: January 4th, 2007, 10:40 AM
  5. chevy 350/turbo 400 recommendations
    By Nuke_HammerinGreenBay in forum Modified Tech Archives
    Last Post: May 25th, 2004, 11:20 PM
