  #101
Old April 26th, 2019, 11:01 PM
M715Fin M715Fin is offline
M715Fin is a Soldier
A few photos of progress...
All did not go as it should have been :/
Need to re-weld ...
  #102
Old May 1st, 2019, 01:42 AM
Yes, it begins to take shape Is the steering axle rubber still available? Somewhere? Does anyone know..
  #103
Old May 27th, 2019, 11:22 AM
Hockey World Champion 2019 FINLAND
  #104
Old June 1st, 2019, 07:49 PM
wolf.dose's Avatar
wolf.dose wolf.dose is offline
Private 1st Class
wolf.dose is a Soldier
Hallo M715 FIN,
Timken is Timken, were ever you buy the bearings. The bearing numbers are allways the same. Radial seals are also standart, CR radial seals are awailable in Europe since SKF bought CR several years ago. Try to buy tese parts at an Industry part supplier. The Tie Rod End Cover are available at Surplus City Jeep Parts, 4514 Pacific Heigths RD, Oroville, CA 95965, US for something like 1,95$ one each (http://originalmilitaryjeepparts.com/m715/M715.htm).
Greetings
Wolf
Since 1980 owner of a M715.
  #105
Old July 9th, 2019, 02:11 AM
Hello everybody. It has been a bit silent for this project. The problem was caused by an old invention. "MONEY". Every time you start repairing something ... Need to buy or order new parts: / I started to power the electricity ... Both of my light switches were broken, I split up both parts and were rusted completely, same was with windscreen wipers So now order more parts...
  #106
Old July 17th, 2019, 09:15 AM
Is the light switch same as m38a1?
  #107
Old July 17th, 2019, 03:53 PM
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
Quote:
More or less yes. The three lever light switch is a mill standard part meaning the same part was used on M38A1, M151s, M35s, M49s, etc. Pick up any three lever light switch from the 60's to - just about present will work.
Zone holster maker
  #108
Old July 17th, 2019, 07:43 PM
Beast's Avatar
Beast Beast is offline
Sergeant
Beast is a Soldier
Quote:
Yes, except that you have to watch out for the ones from the early 50's as they had two plugs instead of the large one. I believe they changed at the same time as the change from Douglas to Packard fittings.
Dave
  #109
Old August 7th, 2019, 09:58 AM
Hello,
Now I got a new light switch. Next, I'll ask you, what position the switch should work ... Headlights, parking light, which light is ser.light or B.O. drive etc? The reason why I ask you can see picture below. whiring was cut off when the car came to me. Are 1. the main power for the switches? 2. Disconnected cables for to tail lights? 3. Tail light wires
  #110
Old August 7th, 2019, 10:06 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
I think 1 is the wires for the horn...3 is the wires that go to the rear harness to run the tail lights/turn signals/stop lights in the rear.
The ones in 2 might be for the front lights but i cant tell from the pic...
What do you have on the firewall for the light system...the large distribution box or the small solid state unit....or something else?
Reference:
Large distribution box:
small solid state unit:
