Old February 21st, 2019, 01:23 PM
plumas.placer.miner plumas.placer.miner is offline
plumas.placer.miner is a Soldier
Default My '68 M715 Build Progress Page
Ok
Old February 21st, 2019, 03:40 PM
66stepside 66stepside is offline
Basic Trainee
66stepside is a Soldier
Whoa, that looks like a great start.
Old February 21st, 2019, 11:11 PM
ok
Old February 22nd, 2019, 07:42 AM
jhartings is a Soldier
That is not too rough. Better than 95% of the M715s out there! I don’t know about the transfer case verification but it looks original and so does the T98. So I would say it has to be a NP200.
Old February 22nd, 2019, 09:03 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
Quote:
Originally Posted by plumas.placer.miner View Post
Okay, so I received my truck from Denver yesterday...
For starters, it boasts a Chevy 250 inline 6 with a chevy transmission (I believe), but a stock transfer case. ...
My wife thinks I am crazy...mining claims and now this?
Very nice start. It appears that you have the original transmission and transfer case so that is a good start. Also, Chevrolet inline 6-cylinder engines are usually pretty reliable. Blue smoke is usually engine oil. It could be valve seals or rings. but for starters, oil is not all that expensive for now.
  #6
Old February 24th, 2019, 11:53 AM
Nailhead's Avatar
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
NP 200 case in the stock OD.
Is that six the one they called the Babbitt Beater?
  #7
Old February 24th, 2019, 06:34 PM
Default Tires and Rims
ok
  #8
Old February 24th, 2019, 06:36 PM
ok
  #9
Old February 25th, 2019, 06:28 AM
Nailhead's Avatar
Corporal
Babbitt is the metal bearing shells are made of, and I think the engine I was referring to was the one used in CCKW & 7107 army trucks, and probably many other vehicles of that time period.
  #10
Old March 26th, 2019, 05:55 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Great truck.
The 250 is a fantastic engine. If I remember right the rear main seal is a 2 piece you can replace without removing the crankshaft from the engine. And the valve cover is prone to leakage after they've been worked on... By that I mean they get bent out of shape easy when they're pulled and won't seal correctly after that. Usually if somebody used a wire wheel to clean the mating surface, that'll deform the metal just enough that it'll leak.
All tins are like that but the old Chevys seemed to be a little thinner metal to me. You might be able to find a new one if that's the case with yours.
And if it's like every other truck on here it'll need new wheel cylinders and rubber lines for sure. and if it's the original master cylinder, the old seal on it will start leaking when you start driving it regularly.
The E350 wheel cylinder conversion and a dual reservoir master cylinder conversion are pretty cheap and easy.
Beautiful plumbing job on your air lines!
